Old 11-26-2015, 03:41 PM #1
vr4z06gt vr4z06gt is offline
vr4z06gt is on a distinguished road
Vibration when towing at highway speed
I am curious if this is a problem that I should be concerned with....I was towing a ~2300lb two axle two horse trailer (empty). I noticed that when under load (on the throttle) at highway speed I would get a vibration (nothing major but it felt like an unbalanced tire) when towing. At speeds <50mph I would not notice this...at speeds>65mph (especially going up hill) I would notice a vibration when under load. If I would let off of the throttle the vibration would almost go way. I would not notice this issue when accelerating from a stop.
Any thoughts?
Happy thanksgiving!
vr4z06gt is offline   Reply With QuoteReply With Quote
Old 11-26-2015, 03:52 PM #2
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
Not supposed to do that. Not sure where to have you start to look. I tow 2-8k occasionally at various speeds and hills, no such problem when I do.
Was there shacking in the steering wheel or the vehicle?
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
Old 11-26-2015, 06:22 PM #3
vehicle. steering wheel was fine.
If it helps 2008 4x4 V8
Old 11-26-2015, 10:06 PM #4
RPS13 RPS13 is offline
RPS13 is on a distinguished road
I get a slight vibration towing between about 65-72 mph in my 2WD V6 with an 18' open steel car hauler with a 240SX on it. I'm guessing it has to do with air vortex shedding from the 4Runner interacting with the trailer/towed car, because it tends to get worse if I'm behind an 18 wheeler. It definitely goes away above 75 mph, and below about 65-62 mph. Kind of annoying since I'd like to be towing about 65-70 mph most places.
I'd say the frequency is roughly 2-3 times a second on the vibration.
'92 Nissan 240SX - 400 HP/2500 lbs
'07 4Runner Sport Edition V6 RWD
RPS13 is offline   Reply With QuoteReply With Quote
Old 11-26-2015, 10:21 PM #5
having fun's Avatar
Real Name: Leonard
having fun's Avatar
Real Name: Leonard
Air turbulence is a possibility for what both of you are getting in vibrations, but I doubt it. I'm not a professional at that stuff.
But as far as when your tailing a big rig, your getting less turbulence unless you have a lot of tailing distance. The closer you are to the rig the less resistance you have on you, the same as Nascar racers follow so close.
Notice how 18 wheelers tend to have another following close to another, better fuel mileage.
Having fun's build
Old 11-27-2015, 12:45 PM #6
The turbulence from vortex shedding can be really severe, so don't discount it.
You're mixing up terms, as you're correct that aerodynamic drag goes down when following another vehicle closely, but the turbulence in the wake will go UP due to what's known as vortex shedding off the bluff body of the trailer.
As you get close to the trailer, the flow will start to become really unsteady and the vortexes can be really strong.
Old 11-28-2015, 08:08 AM #7
humm....interesting responses. I would point out that the trailer is larger than the 4runner. About 8.5 feet high (vs ~6ft for the truck) and also wider than the 4runner. I am planning on towing the trailer home tonight, with about ~2k lbs of stuff, so we shall see what happens.
Thanks everyone for the responses.
Old 02-27-2020, 07:58 AM #8
nikkireed nikkireed is offline
nikkireed is on a distinguished road
highway towing
Which type of truck you are using to tow if you are not company driver you can get an assistant from the Roadside Assistance Services to get solve your problem within a couple of hours.
nikkireed is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 03:13 PM #9
fordhorse fordhorse is offline
fordhorse is on a distinguished road
If it's the v8, have your front axles checked.
Similar rpm as a tire vibe.
Typically under acceleration.
Especially going up hill.
You did all your Diagnostics already.
fordhorse is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 08:24 PM #10
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
Yo nikki! Do you also make spammiches when you play thread Archeology?
Spam post reported
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 10:57 AM #11
AJHappyCats AJHappyCats is offline
AJHappyCats is on a distinguished road
Same issue
Hello,
Did you ever find a resolution to the vibration issue?
We get the exact same problem. Just a slight vibration under load. Like starting from a stop, or pulling up a step hill at highway speed. Ok on flats, at any speed. Feels like drive shaft, transmission, or engine.
Both front axles and wheel bearings have been changed recently, same issue.
2005 V8 3" lift 30" tires
Squats a bit with the tongue weight of our 4000 camper.
AJHappyCats is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 02:26 PM #12
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Originally Posted by AJHappyCats View Post
Hello,
I agree with what fordhorse said above. Front cv axles will cause that during acceleration. I think it's the inner joints that cause it. I've seen it on multiple fwd vehicles. In fact my mother in law recently bought a Honda Odyssey used and when I drove it I told her what she needed. The Honda dealer she bought it from disagreed and after trying a few other things they finally replaced the axles and it was fixed.
importman is offline   Reply With QuoteReply With Quote
Steering Wheel Vibration at Highway Speed...revisited Thai Problems & Warranty Issues 74 12-18-2014 04:42 PM
highway speed vibration OCMike Classic T4Rs 7 03-14-2012 03:41 PM
2001 vibration at highway speed knucklebump General Discussions 0 09-23-2010 12:19 AM
'04 A/C at highway speed ndgogal Problems & Warranty Issues 17 07-28-2004 01:12 PM
