Originally Posted by RPS13
I get a slight vibration towing between about 65-72 mph in my 2WD V6 with an 18' open steel car hauler with a 240SX on it. I'm guessing it has to do with air vortex shedding from the 4Runner interacting with the trailer/towed car, because it tends to get worse if I'm behind an 18 wheeler. It definitely goes away above 75 mph, and below about 65-62 mph. Kind of annoying since I'd like to be towing about 65-70 mph most places.
I'd say the frequency is roughly 2-3 times a second on the vibration.
Air turbulence is a possibility for what both of you are getting in vibrations, but I doubt it. I'm not a professional at that stuff.
But as far as when your tailing a big rig, your getting less turbulence unless you have a lot of tailing distance. The closer you are to the rig the less resistance you have on you, the same as Nascar racers follow so close.
Notice how 18 wheelers tend to have another following close to another, better fuel mileage.
