11-30-2015, 04:37 AM
Vapor Barrier and Butyl Tape
Attached is a picture of the rear vapor barrier mask and its Butyl tape (that's actually what it's called). Does anyone have any idea of how to best remove the tape so I can reapply.
Thanks
2007 LIMITED 4WD V8
Salsa Red Pearl
11-30-2015, 05:07 AM
Real Name: Kevin
Real Name: Kevin
Haha! You'll need a plastic scraper and a dictionary of swear words. A mild solvent will help pick up what the knife misses, but don't use the solvent first or you'll make a terrible mess.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
11-30-2015, 05:48 AM
Oh Lord lolol. Whats your idea of mild?
2007 LIMITED 4WD V8
Salsa Red Pearl
11-30-2015, 08:24 AM
Real Name: Kevin
Real Name: Kevin
You don't want to damage the paint finish if you can help it, stay away from acetone or anything stronger. Denatured alcohol, gasoline, WD40, maybe Goof Off? I've used a shop rag dipped in a little bit of gasoline, seemed to work ok if you can handle the fumes.
Forgot to mention, a heat gun or hair dryer will help you get the rope off in one piece which means less detail work with the solvent. Be careful if you use a heat gun, you can scorch the paint if you get too close.
11-30-2015, 09:36 AM
Before I would mess around with removing it, I would just go over it. Clean it up some and reapply. Personally, I wouldn't worry about it unless you are going into a swamp or in the frozen artic where you don't want the draft.
11-30-2015, 09:40 PM
I wouldn't heat it up too much, it gets very sticky and tacky when it's warmed up and less so when it's cold. You know, sound deadening crap is pretty tacky like that Butyl Tape; any way you could use dry ice to freeze it and then chip it off like you do with sound deadening?
11-30-2015, 09:51 PM
Funny you mention sound deadening. Butyl tape plays an important role in sound reduction.
Not sure how you would incorporate dry ice to freeze the tape on the door(they don't make a dry ice gun?) but I understand your POV. Maybe lots of air duster upside down haha.
2007 LIMITED 4WD V8
Salsa Red Pearl
@ Sungod
What do you mean by "draft"?
2007 LIMITED 4WD V8
Salsa Red Pearl
11-30-2015, 11:51 PM
lol I have three layers of butyl sound deadening on the rear hatch and a fourth that replaced the stock vapour barrier. Completely stopped my rear plate from rattling when my music is cranked, reduced road noise (trunk floor sound deadened too), but the funny thing is that what I liked most about it is it added some weight to the door so it doesn't feel like cheap thin metal when you open and close it
White 2017 TRD Pro
Black 2007 Limited V6 4WD - Sold
12-01-2015, 12:08 AM
What about a can or two of that air-in-a-can that you use to clean keyboards. If you turn that can upside down so that the propellant sprays out instead of the air it's dangerously cold.
They do actually make dry ice guns but they are huge, expensive contraptions that you wouldn't want to buy for a single use.
2004 SR5 4x4 V6 - With New Head Gaskets
12-01-2015, 12:22 AM
Did you replace the actual plastic Barrier? Mine is starting to rip
2007 LIMITED 4WD V8
Salsa Red Pearl
12-01-2015, 09:29 AM
@ Sungod
It functions to keep air out. If you have a hole in the plastic you can get air flowing into the cabin. It really isn't a big deal. In my old car stereo days, would just cut the plastic off rather than deal with it and had no negative effects. The door is sealed pretty well anyway so it isn't that important.
12-01-2015, 10:46 PM
yep.
White 2017 TRD Pro
12-01-2015, 11:23 PM
yep.
Finally someone! I've looked at part diagrams and even spoken with dealerships but still cant find it. What'd you replace it with and where can I buy it.
2007 LIMITED 4WD V8
Salsa Red Pearl
12-02-2015, 10:33 AM
Sheet plastic from Home Depot. But seriously, why bother?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
