Old 07-21-2006, 03:39 PM #1
gonzo's Avatar
gonzo gonzo is offline
gonzo is an unknown quantity at this point
gonzo's Avatar
does your brake pedal go to the floor?
i can routinely press my brake pedal all the way to the floor. when i have already come to a stop and am sitting at a stop light, with very little effort, i can push the pedal all the way down. i spoke with the service department about this and they said that it is completely normal to be able to do this.
seems wierd to me, somewhat unnerving.
anyone else have this "normal" condition on their 4runner?
2004 SE V8 4WD
gonzo is offline   Reply With QuoteReply With Quote
Old 07-21-2006, 04:22 PM #2
xUSNavy xUSNavy is offline
xUSNavy is an unknown quantity at this point
Re: does your brake pedal go to the floor?
Sorry, but my wife has the 4runner today.
If the brake pedal touches the floor, it typically means your brake master cylinder is going out. There is a hydraulic seal in the master cylinder that is allowing brake fluid to pass.
I would go to another dealer and get a second opinion.
xUSNavy is offline   Reply With QuoteReply With Quote
Old 07-21-2006, 04:30 PM #3
Derek's Avatar
Derek Derek is offline
Derek is on a distinguished road
Derek's Avatar
You mean after you're stopped right? Not when you're actually using the brakes to stop, right?
Current: 2007 Limited
Previous: 2004 SR5, 2005 SE V8, 2007 SR5, 2016 SR5
Derek is offline   Reply With QuoteReply With Quote
Old 07-21-2006, 04:34 PM #4
gonzo's Avatar
gonzo's Avatar
yes, after i have already stopped.
2004 SE V8 4WD
Old 07-21-2006, 04:36 PM #5
Derek's Avatar
Derek's Avatar
well, can't say I've tried it, but I'm pretty sure I could push the brake pedal to the floor if I tried.
Old 07-21-2006, 10:42 PM #6
MicaBlue03's Avatar
MicaBlue03 MicaBlue03 is offline
MicaBlue03 is on a distinguished road
MicaBlue03's Avatar
gonzo, I think your service department guy is full of it. I can't see any way you should be able to push the pedal to the floor, at any time, if things are working correctly.
I'd suggest taking it to a different mechanic. I'll bet you've got something failed or broken, but (especially if your 4Runner is 2003 or newer, with the electric brake booster instead of vacuum) I can't say I know much about what the failure would be.
Is the vehicle leaking anything from under the hood or from the wheels?
MicaBlue03 is offline   Reply With QuoteReply With Quote
Old 07-22-2006, 01:10 AM #7
01silverSR5's Avatar
01silverSR5 01silverSR5 is offline
01silverSR5 is an unknown quantity at this point
Pretty sure that is not normal. I have owned many vehicles and I have never had one where the brake pedal would go all the way to the floor. I would get a second opinion.
'03 4runner SR5 V6
'04 Camry
01silverSR5 is offline   Reply With QuoteReply With Quote
Old 07-23-2006, 11:28 PM #8
scooterz scooterz is offline
scooterz is an unknown quantity at this point
brakes
i tried my 06 today and it does not go to the floor. i have the v6.
scooterz is offline   Reply With QuoteReply With Quote
Old 07-23-2006, 11:45 PM #9
TeCKis300 TeCKis300 is offline
TeCKis300 is on a distinguished road
No way is it suppose to go to the floor.
Are you able to press it down to the floor in one swift step? Or does it sink down to the floor gradually with constant pressure? If it's the latter, it's the master cylinder.
'05 Titanium 4x4 V8 Limited 265/70 NTG's
'02 Lexus IS300 Aristo TT swapped
TeCKis300 is offline   Reply With QuoteReply With Quote
Old 07-24-2006, 01:17 AM #10
Ghostface80's Avatar
Ghostface80 Ghostface80 is offline
Ghostface80 is an unknown quantity at this point
My '03 2wd SE does this too! I'm going to the Toyota dealer this Friday to get it checked out.
For anyone in socal, which Toyota dealership do u guys recommend for service? I'm planning to go to Longo.
Ghostface80 is offline   Reply With QuoteReply With Quote
Old 07-24-2006, 02:01 AM #11
Expat's Avatar
Expat Expat is offline
Banned
Expat is on a distinguished road
Banned
Expat's Avatar
I'd vote for Longo or Northridge Toyota (close to me, far from you).
My pedal does not go to the floor.
Expat is offline   Reply With QuoteReply With Quote
Old 07-24-2006, 05:05 AM #12
Koz's Avatar
Koz Koz is offline
Koz is on a distinguished road
Koz Koz is offline
Koz's Avatar
This should not happen ever. If the fluid level is OK you either have a bad master cylinder or air in the line.
Koz
Koz is offline   Reply With QuoteReply With Quote
Old 07-24-2006, 08:31 AM #13
sharp4runr's Avatar
sharp4runr sharp4runr is offline
sharp4runr is on a distinguished road
sharp4runr's Avatar
Yeah this isn't normal. The only time the brake pedal has touched the floor in any of my vehicles is when I've been bleeding the brakes. Otherwise the fluid pressure keeps it from bottoming out.
Take it to a different dealer and get a second opinion. This could turn into a safety issue if you let it go...
sharp4runr is offline   Reply With QuoteReply With Quote
Old 07-24-2006, 08:35 AM #14
boston_kevin's Avatar
boston_kevin boston_kevin is offline
boston_kevin is on a distinguished road
Your pedal should never touch the floor if your brakes are operating properly.
boston_kevin is offline   Reply With QuoteReply With Quote
Old 07-24-2006, 08:47 AM #15
exokomp exokomp is offline
exokomp is on a distinguished road
This happened to me a few times when I first got the truck. In my case it would be difficult to keep the truck stopped at a red light or stop sign as the pedal gradually sank lower and lower.
'06 V8 Sport Edition Titanium 4x4
exokomp is offline   Reply With QuoteReply With Quote
Solved my 3rd-generation 4Runner severe brake pedal pulsation at highway speeds mom 3rd gen T4Rs 33 06-20-2016 01:43 PM
Brake pedal to the floor update Lou Maintenance/Detailing 7 01-05-2007 08:09 PM
Brake fluid maintenance Thai Maintenance/Detailing 4 06-02-2006 04:07 AM
2001 T4R - brake pedal to the floor cracker Problems & Warranty Issues 0 10-10-2004 03:55 PM
Disc & Drum Brakes Thai Maintenance/Detailing 0 11-20-2002 04:32 PM
