09-20-2017, 05:14 PM
#46
Originally Posted by chili
I am continually amazed at the frame rust and rot on *some* of these trucks in the rust belt. Mine has spent its whole like in MA and it's not pretty, but nothing like the above.
My '04 has a rusty radiator support, still structurally sound, skid plate has a fist-sized hole rusted through it, and under the spare tire is kind of ugly, but other than some surface rust on the weld beads, nothing that's going to break anytime soon. It has clearly never been treated, other than my diligence in pressure-washing the underside a few times each winter.
Is it lack of owner care? (Probably) Garaging/not? Simply not driving in the wet/salt? Luck that Toyota used good steel or paint the day they made a particular frame?
While we're on the subject-- one of the worst places on my frame is inside the passenger front wheelwell. Take a look at where the AC condenser drain hose is: right over the frame rail. 13 years of AC water dripping right on the frame. The brake line bracket that's supposed to be there is nonexistent at this point. And yes I know the plastic guard thing is gone... new one is on order.
I want to say it has to do more with the cat heating up that area and salt and rocks getting kicked up there. salt and rocks put mini holes into the rust proofing. maybe a combination of all of the above? my 3rd gen has a hole in a similar area. Right next to the cat.
I suggest just stripping down as much as you can, hope there are no holes and fluid film the crap out of it.
I really should get to rust proofing this year. I have no time though.
2004 limited V8
2002 SR5 V6
10-03-2017, 03:18 PM
#47
, 03:00 PM* #63*(permalink)
farl14
I have a 2003 4Runner with tremendous amount of rust underneath the radiator support is completely gone what we need to do is we need to#Toyota #Toyotarust #toyotadont care #anything that will get Toyota attention they said the more people that complain about the 4th generation 4Runner the more they will have to do something we knock on the door the quicker they will answer post lots of pictures with those hashtags via Twitter Instagram or any social media the big companies do not like that and they have to answer
10-11-2017, 11:50 AM
#48
farl14
welcome im from the bronx as well ! where abouts are you? they pour liquid acid on the roads here.
is it completely hollowed out? grind to whatever metal is left. and fluid film every year.
about to do the same myself.
2004 limited V8
2002 SR5 V6
12-29-2017, 05:12 PM
#49
Real Name: Bob
Real Name: Bob
Originally Posted by Kravman4
He didn't have it installed... I don't have any experience with rusted frames being from southern California. It didn't look good, I just don't know if it's bad enough I should pass up on this 4runner. I may see if he'll let me take it to a dealership to have them check it out...
I seem to remember that a lot of cars don't have a rust prevention coating on them. But, as I recall, there is an aftermarket for this.
Also, there is a product called Rust Dissolver.
Another prevention is to get a pressure sprayer and spray the frame with diesel fuel.
Has anyone had a rust prevention coating applied to their frame?
I know of a product called POR 15 that I have used on my 1982 Vanagan and it is bullet proof. It stops rust cold. The final finish color is black, but you can paint on it. Unless the seal or bond is broken, nothing more is required. They have a starter kit available for a very reasonable cost.
WD 40 works too, but needs frequent reapplication.
Need to insure that your water drain holes are cleaned out.
Also, get an underbody washer that attaches to pressure washer works great, so I am told, to get salt off.
A cheap paint sprayer gun at Harbor Freight, and fill the hopper/canister with either oil or maybe a heavy weight gear lube, or just a good rust preventative oil.
Here's an extremely valuable link to keeping the your prized vehicle from rusting away. 6 Ways to Prevent Rust On Your Car This Winter | BestRide
06-27-2018, 12:47 PM
#50
Real Name: Bob
Real Name: Bob
Undercarriage rust prevention
06-27-2018, 01:26 PM
#51
2004 4wd bought 2 years ago. Currently has 155k miles on it. I knew the frame had rust when I bought it, but didn't realize the extent of it. The radiator support is rotted through in one spot and really heavy rust/scale on the front of the frame, particularly where the control arms mount up. Skid plate rusted out long ago. Power steering and tranny lines on front end were extremely corroded and need replacement. So sad because the engine sounds like it wants to go for another 150k. Why did Tacomas get the frame recall but not the 4runners?
06-27-2018, 02:34 PM
#52
Real Name: Bob
Real Name: Bob
I don't think anyone has that answer. But living in a state that uses SALT on the streets and highways in the winter, for snow control, should be perfectly aware of this and take appropriate steps to prevent frame rust.
Consider how long a car lasts if from the eastern part of the country, compared to the western part of the country.
This might be shocking, but when schools actually had classes to teach students stuff, like Auto Shop, that information was freely taught and out there. So, there goes the education system. Just buy, use, and discard.
07-01-2018, 08:14 PM
#53
Need advice on underside pics of vehicle I'm looking to purchase
This seems like as good a place as any to get some feedback.
I've been looking for a low mileage V8 4wd but everything I've come across looks like it's been at the bottom of the ocean for the past 10years. First and foremost this will be a daily driver, but I want to build it up for overlanding and light offroading (toytech 3" with 5100s and 285 KO2s.)
What's your position on these underside pics? Anything you see here that would make you pass on this one?
West Virginia vehicle, V8 4wd under 100k:
07-01-2018, 08:53 PM
#54
Real Name: Matthew
Real Name: Matthew
It looks like it was undercoated at some point. My concern would be if it was done to hide some bad rust so it looks better/sells easier, or even if it was done with good intentions a bad undercoating can actually make rust worse. Personally, I prefer seeing surface rust rather than undercoating since I like to go through and undercoat slowly and detailed myself and I like to know exactly what I'm starting with; hard to tell in this case.
Instagram: @projectrustyrunner
2003 V8 | Titanium Silver | 180k miles | Uniden CB | Bilstein 5100 Front @1.75" | Extended rear diff breather | American Racing 16" wheels | Full interior LED conversion | Curt roofrack w/ extension
07-09-2018, 06:43 AM
#55
Pre-purchase inspection done: new pics
Update, had the vehicle inspected by a local Toyota mechanic that sent me the following pics. He described it as "pretty rusted," but flaking and no signs of any holes and only apparently surface rust. The worst areas:
Otherwise the inspection was great. Body was in good condition, no check engine lights cleared recently, no leaks, (already has a Flowmaster exhaust added, bonus.) He mentioned it needs tires tomorrow, and likely a power steering pump in the near future, but otherwise was in good condition for a sub 100k mile 15yr old vehicle.
07-09-2018, 06:59 AM
#56
Really don't understand these forums. My reply shows up but the image links I included seem to have dissapeared. Does a moderator need to approve my picture links before they show up or something?
07-09-2018, 09:23 AM
#57
Real Name: Bob
Real Name: Bob
In those worse areas, I would apply a rust stopper like a Por 15 to the area and beyond to a 'clear' area. And keep the frame maintained by coating it with some if the ways that I posted a link about earlier in this thread. You got a keeper!
08-02-2018, 05:16 AM
#58
Real Name: Zach
Real Name: Zach
Autorust T cap system
Don’t wanna revive an old thread, but if your worries about frame holes then this company just started producing 11 gauge steel frame reinforcement pieces that you weld in over your existing frame.
https://www.autorust.com/product-cat...runner/page/2/
04 SR5 V8 4x4, Lift, 285s, MK6 wheels, Full skids, Sliders, F/R breathers, Clazzios, Weathertechs, Polk audio sound, int/ext LED, HIDs in blacked bezels, C4 bumper, XRC 9500, Custom rack/awning mounts/gas/traction board mounts
08-02-2018, 09:29 AM
#59
Real Name: Who's asking?
If you look at the picture with the oil filter visible you can see undercoating on the filter, which means it was done after its last oil change. Looks like the undercoating is meant to hide rust.
2005 4RUNNER V8 4WD -- Sony XAV-AX100 -- Bilstein 5100 shocks -- Wheelers T1/T12 Springs -- 5th Gen Wheels -- 2006-09 Tail Light Conversion -- AFE Pro Dry S -- X2Power 24f -- ScanGauge II...
08-02-2018, 09:55 AM
#60
Real Name: Joe
Real Name: Joe
I definitely agree with you. Im getting my underside professionally undercoated at line-x in a month or two and my friend who works there showed me some pictures of a 4th gen they had done and the difference is night and day from this. I would be very suspicious
2004 SR5 V6 4wd | Bilstein 5100 | OME 884 | Toytec Superflex | 285/70/r16 Nitto Grappler M/T | Pioneer 4800BS 7in Touchscreen | All LED Interior Swap | Custom Grill, Fender and Bumper Paint | Side Exhaust Reroute | Smoked Headlight Swap
