08-02-2018, 09:57 AM
#61
Originally Posted by Zach's Yota
This is funny, I contacted them about a month ago and told them theres a good market to make a frame kit for the 4th gen. I even offered mine as a template as im only 10 minutes away. Looks like they got busy fast!
2005 4Runner Sport 4wd v6 -totaled!
2003 Lexus GX470
08-02-2018, 10:09 AM
#62
Real Name: Matthew
Real Name: Matthew
Awesome, bookmarked!
On a similar topic, does anybody know of a company that makes patches or full replacements for the lower radiator support? (The part way at the bottom that has the tie downs on it.) Only spot that's rotted on mine...
Instagram: @projectrustyrunner
2003 V8 | Titanium Silver | 180k miles | Uniden CB | Bilstein 5100 Front @1.75" | Extended rear diff breather | American Racing 16" wheels | Full interior LED conversion | Curt roofrack w/ extension
08-02-2018, 10:21 AM
#63
Originally Posted by del mar
This right here is the universally best advice. This article even has comments that would get the political correctness people worked up. Doesn't matter where you go in the world, this is what they recommend. Plenty of West Indian mechanics will tell you to do this because their grandfathers did it to stop their cars from rusting away in that coastal environment. If you go to the East Indies, they will tell you the same thing.
08-02-2018, 12:28 PM
#64
Originally Posted by kingofthehill
If you look at the picture with the oil filter visible you can see undercoating on the filter, which means it was done after its last oil change. Looks like the undercoating is meant to hide rust.
Originally Posted by Mullett757
I definitely agree with you. Im getting my underside professionally undercoated at line-x in a month or two and my friend who works there showed me some pictures of a 4th gen they had done and the difference is night and day from this. I would be very suspicious
I passed on this vehicle, which was tough given that it only had 80,000 miles.
I settled on a car that came through the local Atlanta auction last month:
one-owner
dealer maintained
no collision
‘03 Limited
And yes, of course it’s silver.
Mine has some minor surface rusting (no holes) but didn’t have a previous undercoating. Very happy with what I ended up with. I’ll get some pics up as soon as leveling kit, 255/75/17s, and debadging are all done.
08-02-2018, 08:01 PM
#65
Real Name: Skip
Real Name: Skip
Yes, Toyota, here's the radiator support at the following link, the cost is anywhere from $291 and up, the link below is the cheapest one I could find doing a quick search.
https://www.cheapestfactoryparts.com...SABEgJiBfD_BwE
2004 Limited V8
08-02-2018, 09:31 PM
#66
Real Name: Matthew
Real Name: Matthew
Originally Posted by AuSeeker
Ouch. Not cheap, but definitely the right way to get it fixed! Thanks for the link.
08-03-2018, 11:46 AM
#67
Thats the cost of a welder, just sayin'
2003 Lexus GX470
08-04-2018, 10:01 PM
#68
Didn't get out of the NE quick enough. How bad does it look?
08-05-2018, 01:00 AM
#69
Real Name: Matthew
Real Name: Matthew
Perhaps take this with a grain of salt, as I'm from Michigan...but that looks darn near new to me. I wouldn't even think about worrying.
08-05-2018, 02:53 AM
#70
I'll take all the peace of mind I can get!!
08-05-2018, 08:22 AM
#71
Real Name: Skip
Real Name: Skip
Just looks like all surface rust to me, but take a big screwdriver and hitting it with a hammer check any areas that may look really bad
to see how solid the metal truely is, if you don't find any areas that need the rust cut away and new metal welded in clean the frame with a
wire brush and wheel and or a "flap" sanding wheel to remove the worst of the surface rust and then spray a rust converter on the entire
frame!
2004 Limited V8
08-05-2018, 10:50 AM
#72
frame!
Thanks! Now just need the time and tools to work on it. The welding skills are not on board, but I'm sure I can find someone to help if it comes to that.
2003 4Runner SR5 V6 4WD
08-05-2018, 10:54 AM
#73
I was thinking about taking mine to a welding shop and having them cut out and weld in a new piece of steel. Probably at half the cost of buying that crossmember.
08-05-2018, 11:14 AM
#74
Real Name: Matthew
Real Name: Matthew
That's probably what I'm gonna do, and have custom shackle mounts made for the front while I'm there. I find it funny that these don't come with solid recovery points in the first place, but that's another thread!
08-05-2018, 11:53 AM
#75
Real Name: Skip
Real Name: Skip
Ya'll might want to check around at some savage yards, you may get lucky and find a frame that has the crossmember/radiator support intact and just cut it out before you go to a welder.
2004 Limited V8
