Originally Posted by earthrealm
update: hooked up guages to the ac system, and found the pressures low, topped up with gas, and ac blows cold at idle, guess my mystery leak is still on, car has been extensively checked by a tech...no leaks found,. would have to try the dye in refrigrant method.
am thinking at low gas levels, the compressor can rerally generate enough pressure for the ac to chill at idle, but on the highway, with rpms in the 15000 range, the compressor is able to generate enough psi for the system to chill
Hi, reviving an old thread since I have the same issue but with a twist.
Since it is bloody hot here in the west and with temperatures over 110+ degrees. it seems my AC cannot get cold fast enough. Once i start driving, especially freeway, it would feel cold, but not ice cold ( not sure if it can be ice cold with the heat outside) .
The problem is, whenever I am at idle. the compressor will not work and it is blowing hot air until I start driving again. Whenever I am at a complete stop, it will start getting warm and then hot or outside temp air.
Here is the twist. Whenever my HVAC display shows the temp outside around 90 something degrees, it will start working normally and feel ice cold on LO to where I actually have to turn the temperature up. It will never feel like this when temps are 100+ , where I wish I can adjust the temperature lower the LO.
I already tried pumping in the refrigerant and the gauge was saying I had enough in there.
Anyone had this issue and found a way to fix it? Thanks. Got two more months of summer, so I am trying to see if I can get the issue fixed before winter comes.
