Originally Posted by BlackWorksInc
Sorry I didn't realize the context of that question. In our vehicles the ABS Tone Rings are internal to the bearings themselves, you can't visually see them. I was thinking of the rear axle on older Toyota trucks that had a separate tone ring.
Sorry for being so vague, and thread jacking. Thanks for catching my question.
This makes sense, and now looking at new hub assemblies, matches what I see through the hole.
Back to square one.
Humour me for a bit more thread-jacking...
The ABS, Traction, VSC lights have been on for a long time.
Did the paperclip thing, and got:
DTC 31 for ABS: Front right wheel speed sensor or wire
DTC 51 and 43 for VSC: ABS general warning indicator, and ECM fault detected
So I checked the continuity of the front right wheel speed sensor wires, from the sensor-side of the wiring harness, to the top of the wheel-well wiring harness connection point. Both wires were fine. Not sure where the rest of the wire goes to, into a ECM of some kind, somewhere...
I checked the impedience of both front wheel speed sensors, and they were almost identical.
Then I pulled the passenger side sensor, broke it in half due to the o-ring being rusted into the hub. Swearing. Sanding of rust. Replaced the sensor with a new one.
Disconnected the battery. Did a 0-point calibration.
I'll check for AC voltage on the sensor wiring harness when spinning the tire tomorrow. That's about all I know to test now.
