Old 01-18-2016, 08:23 PM #1
Brobertson300 Brobertson300 is offline
Brobertson300 is on a distinguished road
Which leveling kit?
Ive been doing some research on which front leveling kit to buy and what size. I've looked at hundreds of pictures of people builds to try and get a idea how big of a spacer to get but I'm still unsure. I just want to get rid of the rake but not have the front end riding high. Any suggestions on size and brands?
Brobertson300 is offline   Reply With QuoteReply With Quote
Old 01-18-2016, 08:37 PM #2
Morphyne Morphyne is offline
Morphyne will become famous soon enough
there is a lot to read on here I know. but this is w great place to start.
4th Gen Suspension Options/FAQ
Morphyne is offline   Reply With QuoteReply With Quote
Old 01-18-2016, 08:38 PM #3
Brian3676 Brian3676 is offline
Brian3676 will become famous soon enough
I have the daystar. Rides great and looks good
Brian3676 is offline   Reply With QuoteReply With Quote
Old 01-18-2016, 08:39 PM #4
groverdill groverdill is offline
Real Name: Joe
groverdill is on a distinguished road
Real Name: Joe
Pretty much any 1" spacer should do, remember 1" spacer will give 2" lift.
groverdill is offline   Reply With QuoteReply With Quote
Old 01-18-2016, 08:39 PM #5
Powder_Hound's Avatar
Powder_Hound Powder_Hound is offline
Real Name: Neil
Powder_Hound is on a distinguished road
Real Name: Neil
Uhm...What year and Engine are you running.
I think, based on feedback under suspension sticky, and my own personal experience that for leveling purposes the Revtec or Daystar spacers are the simple solution. No need to replace springs and struts for leveling. It's my understanding that the rake is usually 1-2" depending on vehicle and engine. Many will use a 2" on front and 1" on rear leveling kit.
I did a 2 1/2 and 1 1/2 Daystar years ago and it worked out great!
1st was an 87, 2nd was a 95 and 4th gen is a 04 V8 Sport. OME 885/Toytec RCC2.0HD, SPC UCA's, RCI Sliders with top tread, Airlift 1000, and BFG ATKO2's - 265/70/17's. Tekonsha brake controller, EBay interior LED's, and Kenwood DDX 594 radio. Yakima roof rack for all seasons up top.
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
Powder_Hound is offline   Reply With QuoteReply With Quote
Old 01-18-2016, 08:46 PM #6
Southernbike Southernbike is offline
Southernbike is on a distinguished road
I used the Daystar, love the way it looks. The only thing, after I installed it, the right rear was sagging a bit. This is a common problem from what I have read on here. Cornfed suspension will custom make you a spacer for the rear to level it from side to side depending on how much you need. The rear spacer was very easy to put on.
Southernbike is offline   Reply With QuoteReply With Quote
Old 01-18-2016, 10:23 PM #7
I have a 2007 sport v6. I'm just looking to level out the front not really lift the whole truck.
Old 01-18-2016, 10:47 PM #8
Real Name: Neil
Real Name: Neil
You could try this:
Daystar? - Driven by Design
It's a Daystar 1" front spacer. This should net you 1-2" of rise for your front sus only. Some claim 1"'spacer on front nets 2" of lift, but I'm not 100% sure this is accurate, 'cause it will depend on the condition/life left of your coils. Cornfed and Revtec make similar.
Old 01-18-2016, 11:05 PM #9
MrRoo's Avatar
MrRoo MrRoo is offline
MrRoo is on a distinguished road
MrRoo's Avatar
I have the Daystar 1" leveling kit. The newer style. Sits perfectly level now. 1" did net 2" lift on mine. Only thing now is when towing a heavy trailer the rear is low. Maybe I'll get some airlift bags in the rear when towing heavy car hauler trailer.
97 SR5 loaded. (sold)
98 SR5. (Sold)
2004 V8 Limited Current DD
2010 Highlander Limited wife driver and kid hauler
MrRoo is offline   Reply With QuoteReply With Quote
Old 01-18-2016, 11:05 PM #10
You could try this:
I will give it a shot. It's cheap enough. My 4Runner has 180xxx miles on it and original xreas suspension.
Old 01-18-2016, 11:23 PM #11
Real Name: Neil
Real Name: Neil
I've got Airlift 1000 airbags in mine which solved the dilemma you describe. Now my T4R sits level when towing. Pretty affordable, and not an overly difficult mod if you do yourself.
Old 01-19-2016, 12:36 AM #12
Just ordered the daystar 1" leveling kit for the front for $40 shipped. Hopefully it works well! Thanks guys!
Old 06-23-2019, 10:37 PM #13
Calebjwest25 Calebjwest25 is offline
Calebjwest25 is on a distinguished road
I know what you mean of the 1:2 ratio for the front, but I'm looking into getting a 2" leveling kit and some products I'm seeing are named "2.5" Lift Poly Front Coil Spacer Kit". So does that mean it is a 2.5" lift or 2.5" spacer with a net 5" lift?? That seems incredibly excessive to me so I would assume it means the product is a 2.5" net lift (1.25" spacer) right? I'd rather ask than assume things!
Calebjwest25 is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 06:03 PM #14
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
I think on the daystar 2.5 front lift the spacer is roughly half that thickness if I recall.
However on mine I added the KYB front complete struts and ended up a little higher on the the front by a hair due to that combo. I think stock struts would be ok. I can tolerate it, but might end up going with a different setup in 30k miles to make the rear higher.
gaber6 is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 07:26 PM #15
05RedRunner's Avatar
05RedRunner 05RedRunner is offline
05RedRunner is on a distinguished road
New to the group
So if I understand you correctly, a 1" spacer = 2" lift
05RedRunner is offline   Reply With QuoteReply With Quote
Leveling?? Ron4RNevada 5th gen T4Rs 4 01-14-2015 02:24 PM
leveling kit whiskeytyler 4th Gen T4Rs 5 02-03-2014 03:57 PM
Leveling a 2wd?!? Cajun_Limited 5th gen T4Rs 3 01-15-2014 08:46 AM
toytec 2" front leveling kit vs. daystar 2.5" front leveling kit Rolltide10 4th Gen T4Rs 0 03-03-2009 11:58 PM
leveling kit cennijimenez 4th Gen T4Rs 1 10-13-2008 02:18 PM
