Old 02-04-2016, 06:08 PM #1
dleeallen dleeallen is offline
dleeallen is on a distinguished road
Front Upper Ball Joint - replace arm or joint?
My 05 V8 has a loose left front upper ball joint. Debating which way to go replacing it - the full OEM arm or aftermarket ball joint. Any good reasons to go either way?
I'm going to have a shop do it since I don't have a good place to deal with it in the winter. The labor is more for the balljoint but the arm costs significantly more. I think the arm will still end up more money.
Thanks for your opinions.
dleeallen is offline   Reply With QuoteReply With Quote
Old 02-04-2016, 08:27 PM #2
T101 T101 is offline
T101 is on a distinguished road
I've never swapped just the ball joint but can tell you that swapping in a new upper arm is relatively easy with basic hand tools. Taking your time it shouldn't take more than a couple hours.
05 SR5 V8 Build Thread http://www.toyota-4runner.org/4th-ge...101-build.html Ditch/DRL/Turning Signal Mod http://www.toyota-4runner.org/4th-ge...ignal-mod.html
T101 is offline   Reply With QuoteReply With Quote
Old 02-04-2016, 09:37 PM #3
dkyleb's Avatar
dkyleb dkyleb is offline
Real Name: Kyle
dkyleb is on a distinguished road
dkyleb's Avatar
Real Name: Kyle
Pulling the balljoint on the stock arms is somewhat risky, as the stock arms are pretty thin. Not saying it cannot be done, it's just most places recommend replacing the whole arm.
Are you running any lift?
2015 SR5 T4R :: ordering parts.
2004 V8 T4R :: just a bunch of crap off ebay bolted on to a rusty toyota. (build thread.)
dkyleb is offline   Reply With QuoteReply With Quote
Old 02-04-2016, 10:20 PM #4
Cisco Kid's Avatar
Cisco Kid Cisco Kid is offline
Real Name: Jeff
Cisco Kid will become famous soon enough
Cisco Kid's Avatar
Real Name: Jeff
Replacing the whole arm should only take 30 to 45 minutes. The ball joint can be replaced as well and doesnt take much more time. I replaced the joints in my OEM arms before buying a set of Camburgs.
2015 Limited, bone stock for now
Cisco Kid is offline   Reply With QuoteReply With Quote
Old 02-04-2016, 10:42 PM #5
No lift. Just a rusty stock truck. Lol. Probably an arm makes sense. I should start soaking everything with pb blaster now.
Old 02-04-2016, 10:52 PM #6
Morphyne Morphyne is offline
Morphyne will become famous soon enough
Why would you replace the arm for $300? Check you tube. Upper ball joints are jot that bad and your out like $20.
Morphyne is offline   Reply With QuoteReply With Quote
Old 02-05-2016, 12:08 AM #7
That's the question. Seems very mixed opinions. If stock truck just go moog joint?
Old 02-05-2016, 12:14 AM #8
Absolutely. Rock auto has them for cheap. YouTube chrisfix and balljoint. He makes it look extremely easy.
Replace upper ball joint or entire control arm? brianhuntRVA 4th Gen T4Rs 6 08-04-2015 08:21 PM
upper ball joint HElP ME! OrangeChicken123 3rd gen T4Rs 44 06-20-2015 08:48 PM
Bad Upper Ball Joint or....... xcmountain80 3rd gen T4Rs 2 05-31-2015 02:36 PM
I Need Help...Upper Ball Joint Bigger_Is_Better 3rd gen T4Rs 8 01-03-2015 08:24 PM
upper ball joint mien4x4 3rd gen T4Rs 29 08-17-2012 08:05 AM
