Thread Tools Rating: Thread Rating: 2 votes, 3.50 average. Display Modes
Old 12-07-2019, 08:35 AM #736
evan1242's Avatar
evan1242 evan1242 is offline
evan1242 will become famous soon enough evan1242 will become famous soon enough
evan1242's Avatar
Kenwood DDX9706S
evan1242 is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 03:54 PM #737
bjward bjward is offline
bjward is on a distinguished road
Originally Posted by Chiefboone View Post
Where were you able to find that specific headunit?
Occasionally, you can find them on Ebay, but they are pretty rare. If you can't find one there, you can pick one up from a Toyota Dealership (not as cheap of an option though). Yaris Standard Audio - Toyota (PT546-52150) | Toyota Parts
bjward is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 05:27 PM #738
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
Bout ready to tackle replacing the OE speakers and wanted to ask if anyone knows the part number for the clips that hold the interior door panels to the door frames? Just in case i bust some of them i can easily find replacements.
Thanks!
jrm is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 10:25 PM #739
JonLasaga JonLasaga is offline
JonLasaga is on a distinguished road
In mine I added a gta car kit that just adds auxillary and bluetooth because I wanted to keep the stock radio. It was a good upgrade from the original that only had a disc and tape. I looked into adding a new radio in alltogether at the same time and I decided it was too much work becuase the dash peices are kinda irregular but im sure it would be possible. Probably not what you are looking for but if you like a project you can make a radio with touchscreen from a single board arm computer. https://www.youtube.com/watch?v=pS8wbvQx0h4
JonLasaga is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 12:42 AM #740
Kryptoroxx's Avatar
Kryptoroxx Kryptoroxx is offline
Real Name: John
Kryptoroxx has a spectacular aura about Kryptoroxx has a spectacular aura about
Kryptoroxx's Avatar
Real Name: John
Just finished up my atoto a6 pro for the yota. No adapter needed for the dash. Pretty good sound quality and it's a droid so tons of pluses there. Connects to wifi, dual bt, supports wifi dash cams, backup cameras, and all your favorite droid apps.
Sent from my SM-G965U using Tapatalk
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
Kryptoroxx is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 11:37 PM #741
gn9119 gn9119 is offline
gn9119 is on a distinguished road
I'm about to throw my hands up after searching for a "branded" head unit to integrate with my existing 06 jbl synthesis system. These unit seem to check all the boxes and then some at a cheapass price but... still sketchy on these units.
What's the display like...that night shot looks way too bright for me. My eyes are sensitive and looking at a glowy, cheap display day in and day out would nullify any interest in this thing.
gn9119 is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 01:45 AM #742
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
You can adjust the brightness. I turned mine down and it's good. Plus most of the apps I use have a "night" mode and it goes to a darker color.
Old 12-21-2019, 12:09 PM #743
Which specific model did you get? I'm gonna grab one...i asked Atoto about fitment and they responded:
Please kindly note that the specific car radio A6YTY721PR only fits the vehicle whose dashboard opening dimension is 205*104 mm.
If the dashboard opening dimension of your vehicle is not 205*104 mm, perhaps you can consider our universal double-din car radios,
for instance, A6Y2721PR and A6Y2721PRB.
But you may need to purchase additional fitting kits to complete the installation
I want a premium unit with the IPS screen, which now is only avail in the 2721 i believe. What other accessories did you get from them, if any? camera, obd2, etc.
thank again
Old 12-23-2019, 02:03 PM #744
Kryptoroxx's Avatar
Real Name: John
Kryptoroxx's Avatar
Real Name: John
thank again
[New] ATOTO A6 Pro Android Car... https://www.amazon.com/dp/B075W9H5P3...p_mob_ap_share
That's the direct amazon link. If you had the factory nav then you should be good to go.
I didn't need to get anything else from them but you can hook up an obdii reader, dash cam, and a backup camera easily. Even the steering wheel controls hook up directly. You just need to get an adapter for the jbl amplifier.
Old 12-24-2019, 10:40 AM #745
last question (promise)...
-which jbl adapter harness did you go with, the PAC RP4.2-TY11 or the Axxess/Metra TYTO-01 Wiring Interface (or another). My JBL stock unit is only a CD/radio, no navigation. Seems to be a debate online which adabter harness is less prone to having issues. Crutchfield says i need the PAC but i think it may be overkill considering what the Atoto unit already has.
-How is your radio reception and what did you do re the radio antenna...did you go with the Y adapter:
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
-did you retain fade controls with the system.
I'm looking at the A6T2721BRB...i would need a mount bracket since it's narrower.
Old 12-24-2019, 11:00 AM #746
Which harness did you use, assuming you integrated it with the JBL stock amp.
Originally Posted by V8Limited4wd View Post
Installed an ATOTO A6 Pro Android HU for Toyota along with a Pioneer sub that fits in the factory box. Factory SWC and backup camera are wired up and working. Everything works perfectly and I'll also be getting an adapter to use Apple CarPlay.
Old 12-25-2019, 09:31 PM #747
Chiefboone Chiefboone is offline
Chiefboone is on a distinguished road
Would this work for JBL synthesis speaker system?
Chiefboone is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 11:22 PM #748
iamBazzy iamBazzy is offline
iamBazzy is on a distinguished road
Something i'm working on, decided to do an iPad mini without using a head unit. Still need to work on the bezel, but it's all functioning how I wanted. Replaced the door speakers with some 6x9 and 6.5 units, powered by a 4 channel amp. Mono amp for a 10" sub in the back. Everything is wired into that equalizer, which then hooks into the ipad directly. The little knob in the dummy console switch is to control the volume. The iPad is jailbroken, so it auto powers on/off with ignition, and uses my phone's hotspot. The one thing I'm still considering is getting the steering wheel controls back, but I haven't found anything that would be seamless just yet
iamBazzy is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 01:15 PM #749
that's a nifty little setup. i'd love to have a volume knob down there.
Old 12-30-2019, 08:28 PM #750
PhantomF4E PhantomF4E is offline
PhantomF4E is on a distinguished road
So I'm not sure if this is the correct thread, but here goes nothing...
About a year ago, I got a JVC KW-V840BT in-dash entertainment system installed. A decent touchscreen display, bluetooth audio, and Sirius plus Apple CarPlay support. In general I've been very happy with it. That said, recently it has started just randomly turning off, It then reboots a few seconds later, and eventually a screen will come up saying I need to park the car, turn off the ignition, and then turn it back on. This only seems to happen when I'm trying to use SiriusXM or if I get a text or phone call while my phone is plugged in and Apple Play is displayed on the screen. I e-mailed JVC to see if they can be of assistance, but just thought I'd try here too.
PhantomF4E is offline   Reply With QuoteReply With Quote
If when these upgrades will come to 4R? NoDak General Discussions 6 02-28-2014 08:50 AM
3rd Gen UPGRADES? OffRoadBuck 3rd gen T4Rs 12 02-13-2014 12:01 PM
Upgrades for '94 AZ4runnerPrerunner Classic T4Rs 12 07-28-2013 10:31 PM
Mid-3rd Gen Upgrades... CoMarc 3rd gen T4Rs 17 07-01-2010 10:29 AM
'06 LTD V8 - Top 3 must-have upgrades? RedRacer 4th Gen T4Rs 8 10-04-2007 11:35 AM
