11-18-2021, 10:08 AM
#886
I went with an Alpine ILX-207 from Crutchfield. I wanted CarPlay, a backup camera and to be able to use my steering wheel controls again. It does what I need it to do now.
11-18-2021, 11:03 AM
#887
Originally Posted by Jmonteil
Hoping someone can answer a simple question I’m having a hard time finding a clear answer for:
if I opt to utilize the factory JBL amp/system with my new head unit, does that mean the head unit amp is completely useless? Or do they combine somehow? So there is no audio benefit from the new deck?
Well if you are replacing the head unit you may be loosing some of the amplification the stock head unit provides. Depending on the new head unit/deck it may provide an audio benefit, depends if its amplified.
Swapping head units is not a simple as that. You may have to run a DSP, replace the amps....
11-20-2021, 12:14 PM
#888
Originally Posted by bebop
I am currently working on installing Pioneer MVH-1400NEX on my 2008. I have the factory JB and all associated steering wheel buttons and components. Just did a preliminary wire setup and am a little confused (don't have the center console apart yet so not sure which 24 Pin to use)
Seems pretty straight forward, I'll return once finished.
Edit: I bought everything from Crutchfield and purchased the HRN-RR-T01 Harness and the Maestro RR to retain all OEM functionality.
How did this turn out? Is Maestro the key to retaining all factory stuff? I have a 2007 with nav/JBL and want to keep everything functional as it is now, just add Apple CarPlay. Even the factory JBL speakers/sub sound good enough to me
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
11-20-2021, 04:25 PM
#889
Real Name: Sean
Real Name: Sean
Everything worked as it should based on the instructions from crutchfield. They refunded the additional piece that was not needed (believe the 24 gauge cord). Super simple, 1st time soldering and turned out beautiful!!
The only issue I still have is the microphone for the new deck doesnt work with the OEM install microphone so you may have the same issue. I just choose not to install the mic so its ultimately on myself. Cheers!
2008 V8 4Runner Limited- Stock
1999 3rd Gen Limited
2020 TRD ORP
11-20-2021, 11:13 PM
#890
How does the sound compare to stock? I personally like how my Nav/JBL sounds lol, just wish I had CarPlay functionality.
11-21-2021, 09:41 PM
#891
Real Name: Dave Penney
Here's mine. Love it. It's a ZHNN.. Works great.
11-28-2021, 03:14 AM
#892
Just spent all day today wiring in a Pioneer DMH-1500NEX. Seemed to be the only reasonably priced one available online. Picked up the full Maestro kit from Crutchfield as well. Overall not a bad experience other than me being colorblind lol. Lots of learning about what wires matter and which don't, where to plug things in, how to program the Maestro etc. Overall happy with the interface with the steering wheel controls and the factory JBL speakers/amp/sub. Sounds better than stock too, lots of tune-ability.
12-29-2021, 10:25 PM
#893
Originally Posted by waught10
Got a good deal on a 2019 Toyota 86 head unit.
What is the part number for this? Thanks
01-09-2022, 12:27 PM
#894
Sony avx3000 installed on the factory jbl system. Everything is working great except steering wheel Controls, I'll be getting the SWI module soon. Also added backup camera.
Sent from my SM-G998W using Tapatalk
01-09-2022, 01:39 PM
#895
Recently installed a Kenwood DMX 10.1. Had some nice surprises like tire pressure and tire temp as well as some extra gauges. It even reads off codes and can reset them.
01-09-2022, 02:39 PM
#896
That Kenwood is slick, Ripper!
01-09-2022, 02:51 PM
#897
Here's mine with a Pioneer installed. Have the maestro wiring harness so it maintained the steering wheel controls. USB plug in put into one of the open slots by the center console.
01-10-2022, 02:54 AM
#898
Real Name: Taylor
Real Name: Taylor
Originally Posted by kingnba6
Installed.
How have you liked this unit?
Sent from my Pixel 3 XL using Tapatalk
1985, 22re, 5spd, 4x4, Marlin crawler dual transfer case, locked fr&rr, 35's
1996, 5vz-fe, Auto, 4x4, Bilstein/ome lift, tundra 17's, 33's
Sold(regret it)- 1999 Highlander edition, Auto 4x4, 3"lift, factory rear locker
01-10-2022, 12:59 PM
#899
Installed a Pioneer DMH-1770NEX this weekend. Actually installed it 3 times because I'm bad with directions (forgot to attach the mic first time, plugged backup camera into wrong input second time).
The unit was cheap ($300 at Best Buy on sale), has capacitive touch screen, android auto and input for the backup camera. Looks good, works good but sound is just ok - I'm using the factory speakers and the old factory headunit (non-JBL) sounded richer. I don't know if I wired something up incorrectly (all speakers work and sound similar, and the color coding was easy to follow) or if the factory unit was designed to work better with the factory speakers and I just need to adjust the equalizer more and/or replace the speakers.
I appreciate all the "how to's" on this forum as it made the radio and backup cam install (along with everything else I've done) easy!
01-13-2022, 12:25 AM
#900
Real Name: Blair
Real Name: Blair
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
