Originally Posted by Danrunner
I haven't really checked out this forum in several years because my '04 succumbed to the head gasket problem. I might go check out an '06 with a ton of miles (but a decent price) this week. I believe the head gasket issues were corrected by that point, but what other potentially serious/expensive things should I check? It seems frame rust might be a concern as well.
Thanks in advance!
Look at the VIN sticker on the driver's door jamb, find the build date, on my 2004 the date is in the upper right corner, if 12-05 or later it will have the updated head gaskets, any date before 12-05 and it will have the old design head gasket and they could fail at some point, some 2006s will have the old designed head gaskets, the build date will tell the tale.
The head gasket issue only applies to the V6 engines, the V8s are fine.
