12-07-2019, 08:35 AM
#736
Kenwood DDX9706S
12-10-2019, 03:54 PM
#737
Originally Posted by Chiefboone
Where were you able to find that specific headunit?
Occasionally, you can find them on Ebay, but they are pretty rare. If you can't find one there, you can pick one up from a Toyota Dealership (not as cheap of an option though). Yaris Standard Audio - Toyota (PT546-52150) | Toyota Parts
12-13-2019, 05:27 PM
#738
Bout ready to tackle replacing the OE speakers and wanted to ask if anyone knows the part number for the clips that hold the interior door panels to the door frames? Just in case i bust some of them i can easily find replacements.
Thanks!
12-13-2019, 10:25 PM
#739
In mine I added a gta car kit that just adds auxillary and bluetooth because I wanted to keep the stock radio. It was a good upgrade from the original that only had a disc and tape. I looked into adding a new radio in alltogether at the same time and I decided it was too much work becuase the dash peices are kinda irregular but im sure it would be possible. Probably not what you are looking for but if you like a project you can make a radio with touchscreen from a single board arm computer. https://www.youtube.com/watch?v=pS8wbvQx0h4
12-15-2019, 12:42 AM
#740
Real Name: John
Real Name: John
Just finished up my atoto a6 pro for the yota. No adapter needed for the dash. Pretty good sound quality and it's a droid so tons of pluses there. Connects to wifi, dual bt, supports wifi dash cams, backup cameras, and all your favorite droid apps.
Sent from my SM-G965U using Tapatalk
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
12-18-2019, 11:37 PM
#741
I'm about to throw my hands up after searching for a "branded" head unit to integrate with my existing 06 jbl synthesis system. These unit seem to check all the boxes and then some at a cheapass price but... still sketchy on these units.
What's the display like...that night shot looks way too bright for me. My eyes are sensitive and looking at a glowy, cheap display day in and day out would nullify any interest in this thing.
12-19-2019, 01:45 AM
#742
Real Name: John
Real Name: John
You can adjust the brightness. I turned mine down and it's good. Plus most of the apps I use have a "night" mode and it goes to a darker color.
12-21-2019, 12:09 PM
#743
Which specific model did you get? I'm gonna grab one...i asked Atoto about fitment and they responded:
Please kindly note that the specific car radio A6YTY721PR only fits the vehicle whose dashboard opening dimension is 205*104 mm.
If the dashboard opening dimension of your vehicle is not 205*104 mm, perhaps you can consider our universal double-din car radios,
for instance, A6Y2721PR and A6Y2721PRB.
But you may need to purchase additional fitting kits to complete the installation
I want a premium unit with the IPS screen, which now is only avail in the 2721 i believe. What other accessories did you get from them, if any? camera, obd2, etc.
thank again
12-23-2019, 02:03 PM
#744
Real Name: John
Real Name: John
thank again
[New] ATOTO A6 Pro Android Car... https://www.amazon.com/dp/B075W9H5P3...p_mob_ap_share
That's the direct amazon link. If you had the factory nav then you should be good to go.
I didn't need to get anything else from them but you can hook up an obdii reader, dash cam, and a backup camera easily. Even the steering wheel controls hook up directly. You just need to get an adapter for the jbl amplifier.
12-24-2019, 10:40 AM
#745
last question (promise)...
-which jbl adapter harness did you go with, the PAC RP4.2-TY11 or the Axxess/Metra TYTO-01 Wiring Interface (or another). My JBL stock unit is only a CD/radio, no navigation. Seems to be a debate online which adabter harness is less prone to having issues. Crutchfield says i need the PAC but i think it may be overkill considering what the Atoto unit already has.
-How is your radio reception and what did you do re the radio antenna...did you go with the Y adapter:
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
-did you retain fade controls with the system.
I'm looking at the A6T2721BRB...i would need a mount bracket since it's narrower.
12-24-2019, 11:00 AM
#746
Which harness did you use, assuming you integrated it with the JBL stock amp.
Originally Posted by V8Limited4wd
Installed an ATOTO A6 Pro Android HU for Toyota along with a Pioneer sub that fits in the factory box. Factory SWC and backup camera are wired up and working. Everything works perfectly and I'll also be getting an adapter to use Apple CarPlay.
12-25-2019, 09:31 PM
#747
Originally Posted by bjward
Would this work for JBL synthesis speaker system?
12-27-2019, 11:22 PM
#748
12-29-2019, 01:15 PM
#749
Originally Posted by iamBazzy
Something i'm working on, decided to do an iPad mini without using a head unit. Still need to work on the bezel, but it's all functioning how I wanted. Replaced the door speakers with some 6x9 and 6.5 units, powered by a 4 channel amp. Mono amp for a 10" sub in the back. Everything is wired into that equalizer, which then hooks into the ipad directly. The little knob in the dummy console switch is to control the volume. The iPad is jailbroken, so it auto powers on/off with ignition, and uses my phone's hotspot. The one thing I'm still considering is getting the steering wheel controls back, but I haven't found anything that would be seamless just yet
that's a nifty little setup. i'd love to have a volume knob down there.
12-30-2019, 08:28 PM
#750
So I'm not sure if this is the correct thread, but here goes nothing...
About a year ago, I got a JVC KW-V840BT in-dash entertainment system installed. A decent touchscreen display, bluetooth audio, and Sirius plus Apple CarPlay support. In general I've been very happy with it. That said, recently it has started just randomly turning off, It then reboots a few seconds later, and eventually a screen will come up saying I need to park the car, turn off the ignition, and then turn it back on. This only seems to happen when I'm trying to use SiriusXM or if I get a text or phone call while my phone is plugged in and Apple Play is displayed on the screen. I e-mailed JVC to see if they can be of assistance, but just thought I'd try here too.
