Thread Tools Rating: Thread Rating: 2 votes, 3.50 average. Display Modes
Old 01-15-2022, 08:21 PM #901
kingnba6 kingnba6 is offline
kingnba6 is on a distinguished road
Originally Posted by TLar25 View Post
How have you liked this unit?
Sent from my Pixel 3 XL using Tapatalk
I like the android unit a lot. The price, quality and features are a no brainer for the price point. The OEM fitment and style are the main reason I used this unit.
kingnba6 is offline   Reply With QuoteReply With Quote
Old 01-18-2022, 05:13 AM #902
weespeed weespeed is offline
weespeed is on a distinguished road
I like the look. What did you have before? JBL, rds system?
Thanks
weespeed is offline   Reply With QuoteReply With Quote
Old 01-29-2022, 01:37 PM #903
xyrcncp xyrcncp is offline
xyrcncp is on a distinguished road
Originally Posted by Ventil8 View Post
Had this installed a month ago...upgrade from a Kenwood 891HD head unit. Love it.
@Ventil8 quick question about your setup. I see you get your PSI info, does that info come up because I assume you have the iMaestro link installed? I've been out of the 'audio game' for a long time and I assumed that type of information would only come up in newer cars and that the 4th gen didn't have that info available. However, I'm planning on installing a new HU shortly.
xyrcncp is offline   Reply With QuoteReply With Quote
Old 01-30-2022, 09:24 AM #904
Ventil8 Ventil8 is offline
Real Name: Armando
Ventil8 will become famous soon enough Ventil8 will become famous soon enough
Real Name: Armando
@xyrcncp Yes, the PSI/temp info comes up because of the updated Maestro idatalink module. When I updated the head unit, i planned to use the old Maestro module that I was using to save money. Unfortunately, the Maestro module was not compatible with the newer CarPlay head unit that I bought. I bought the newer Maestro module for my HU and to my surprise, I was getting actual PSI/Temp numbers.
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
Ventil8 is offline   Reply With QuoteReply With Quote
Old 01-30-2022, 11:32 AM #905
Thanks a lot for the info. I honestly had no idea the PSI/Temp numbers would report to a HU from our generation 4Rs
Old 01-30-2022, 11:54 AM #906
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I don't think it works on 2003 and 2004 year models, only 2005 and onwards.
2004 Limited V8
Old 01-30-2022, 12:44 PM #907
Good to know thanks! Though I have a 2006, which I should've mentioned
Old 02-23-2022, 12:59 AM #908
V8Limited4wd's Avatar
V8Limited4wd V8Limited4wd is offline
V8Limited4wd is on a distinguished road
ATOTO A6 Pro for Toyota w/OBDII Bluetooth adapter and Metra TYTO-01 JBL amp harness. Steering wheel controls and OEM backup cam directly wired to the HU. No faceplate needed.
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
V8Limited4wd is offline   Reply With QuoteReply With Quote
Old 02-23-2022, 11:34 AM #909
ncrooks's Avatar
ncrooks ncrooks is offline
ncrooks is on a distinguished road
ncrooks's Avatar
What are you using for the gauges on the radio? I was looking at Maestro but it does not list the 2004 V8 as compatible.
2004 Sport 4.7L Bilstein 5100s with OEM FJ coils
ncrooks is offline   Reply With QuoteReply With Quote
Old 02-23-2022, 11:49 AM #910
I’m using the Torque Pro app connected to an OBDII Bluetooth adapter.
2004 V8 LIMITED 4WD
Old 02-23-2022, 01:00 PM #911
ncrooks's Avatar
ncrooks's Avatar
Thanks. Do you have to have the app on your phone or can you load it directly to the radio? I don't believe they off that app on Iphone.
Old 02-23-2022, 02:35 PM #912
Radio Upgrades... Let see them.
It’s an Android HU that can run apps from the google play store. Also does Apple carplay with an adapter you buy separately.
2004 V8 LIMITED 4WD
Old 03-10-2022, 10:12 PM #913
subdued76 subdued76 is offline
subdued76 is on a distinguished road
I have been trying to research as much as possible, but need some help. I just bought a 2005 Limited 4runner with JLB navi. The screen is black all the time so I assume the head unit is shot, although sound comes through.
I'm looking at my options now. I would like to use the factory rear view camera, but not sure how to get that to work with an aftermarket head unit. I have thought about buying a used jbl unit without the navi. Will that work? Can I put any jbl marked toyota head units in the 4runner since thats what I currently have?
subdued76 is offline   Reply With QuoteReply With Quote
Old 03-14-2022, 02:59 PM #914
RoyBell RoyBell is offline
RoyBell will become famous soon enough
This is the rats nest of wires and harnesses and adapters Crutchfield sold me to make this radio work. I confirmed everything worked before closing it all up. Buttoned everything up, and of course the backup camera doesn't work now. I made sure to tape the RCA jacks so it wouldn't come unplugged so I can only imagine what happened.
Just the Toyotas
'86 FJ60
'07 4R V8
RoyBell is offline   Reply With QuoteReply With Quote
Old 03-14-2022, 06:47 PM #915
Did you have the JBL system?
If when these upgrades will come to 4R? NoDak General Discussions 6 02-28-2014 08:50 AM
3rd Gen UPGRADES? OffRoadBuck 3rd gen T4Rs 12 02-13-2014 12:01 PM
Upgrades for '94 AZ4runnerPrerunner Classic T4Rs 12 07-28-2013 10:31 PM
Mid-3rd Gen Upgrades... CoMarc 3rd gen T4Rs 17 07-01-2010 10:29 AM
'06 LTD V8 - Top 3 must-have upgrades? RedRacer 4th Gen T4Rs 8 10-04-2007 11:35 AM
