Originally Posted by LTDSC
So im guessing yesterday when i had two wires swapped it must have fried my MAF. I connected the wires properly and was able to clear all but the IAT P0113 code. I've cleaned the MAF and checked my soldering and its all good. I'm pretty much guessing at this point but it seems logical i might have fried the IAT port on the MAF when i had it wired incorrectly.
I'm guessing you had it wired up:
Pin 1- Brown
Pin 2- Blue w/ White
Pin 3- Yellow w/ Black
Pin 4- Black w/ White
Pin 5- White w/ Red
Meaning you swapped Pins 2 & 3 (Yellow w/ Black should be on Pin 2 an Blue w/ White is on Pin 3)
Hmm... it is possible you shorted out the MAF, or unfortunately you may have damaged the ECM.
Blue w/ White is Supply Voltage (12~14v) into the MAF, while Yellow w/ Black is the signal voltage for the IAT into the ECM. According to the FSM, the ECM is expecting .5~3.4v into the ECM to measure Intake Air Temperature; if you reversed the wires that means supply voltage went in.
Now before you panic, that's just a possibility; it may not be what happened. The MAF may not have liked having supply voltage flowing backwards through it (I don't know if thermistors are directional.)
Can you see the DataList (via whatever tool you're using for pulling DTCs) for the vehicle and see what the IAT reading is? If you can back probe the Yellow w/ Black wire (now that it's correctly installed) you shouldn't see voltage more than 3.4v (though you may see it between .5 and 3.4v) which would indicate that the IAT is working as designed and the issue might be at the ECM.
