02-17-2016, 01:17 AM
Gobi Rack - Issue with mounting brackets and loose bolts?
Hi All,
After I installed my rack, I noticed that my mounting bracket bolts were slightly loosened, so I tightened them back up and called it a day.
Yesterday, I checked on the bolts again and they still seemed loose, so I tightened them till the point where my thumb couldn't push the wrench anymore (so definitely not forcefully tightening them) and called it a day.
Well tonight I just checked on them again, and they're loose again! Not like super loose, but I had to tighten them back up again maybe a full turn?
I do have some thread sealant on the bolts, but has anyone else experienced this?
Thanks!
02-17-2016, 06:55 AM
maybe add some locktite and lock washers to help? i think the blue is what you want to use, the red is a more permanent solution.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
02-17-2016, 11:42 AM
I second the lock washer idea, or maybe using self-locking nuts.
Has there been a huge difference in the high and low temperatures?
2003 T4R Sport V8 (big wagon)
2004 Subaru Forester XT (small wagon)
02-17-2016, 01:53 PM
Which bolts? The allen bolts or the bolts that bolt to the rack and connect to the Gobi's feet? I tightened the regular feet to rack bolts really really tight. The allen bolts that bolt to the roof of the 4runner I just put some silicone on the threads and tightened them tight but made sure not to over tighten them.
I never used any locktite with my Gobi and never had an issue.
2009 Trail Edition - ICON lift, Total Chaos UCA, BF Goodrich Mud Terrain KM2 285/70/17's, SCS Stealth 6 Matte Gunmetal finish, K9 2.2m Roof Rack.
02-17-2016, 02:00 PM
throw it in the trash!!!
i wouldn't use a split lock washer it would et water in. Get the one that looks like a cog and use some silicone to seal around it too. So, lock washer, washer and some silicone is what i would do. if its loose then water is getting in for sure.
04 4runner Sport Edition V8
-MODS- Maxtrac Lift Spindles | Bilstein 5100/5160| Tacoma frt springs | MT LT 3in reat springs | eBay UCA | SS brakelines | 4crawler body lift | 17 level8 punch | At3 315/70/17 | K&N cai | black clazzios |
Build thread
02-17-2016, 02:44 PM
The 4runner has been in the garage for the past few days, so the temp hasn't fluctuated too drastically.
02-17-2016, 02:45 PM
The allen bolts that bolt the mounting brackets to the roof. I don't think I over tightened them at all, but I'll check again tonight to see if they loosened a bit.
02-17-2016, 02:46 PM
I'm using a sealing washer with some silicone.
02-17-2016, 02:58 PM
Real Name: Ron
Real Name: Ron
Just to verify what's really going on, you might want make a small mark on the allen heads with a permanent marker to see if they're really turning and backing out, or perhaps you have an issue with whatever they're threaded into, that is slowly pulling out of the roof. I don't know how much structure is under the roof to hold those bolts - my guess is less than you'd hope for.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
02-17-2016, 03:02 PM
That would suck if it was the latter!
Basically I installed the roof rack and tightened all bolts. Then I went to check on the bracket bolts again a day later only to find that they weren't tight like how I left them the previous day.
I'll check again tonight.
02-17-2016, 03:47 PM
I've had the same problem with mine. Locktite is not a bad idea. I'm going to give that a try as well, (even though when I installed it- I'm pretty sure I already put some.....?)
As for the split washers etc. I was in disagreement with my friends during the install, i thought the order Gobi suggested was odd...
MY 4RUNNER IS LIVE NOW ON BRING A TRAILER WITH NO RESERVE
2nd Gen (Sold) | T4ROTM Winner
Camping/Overlanding Drawer plans! FREE parts list! -> - TheAdventureIndex.com
02-18-2016, 01:14 AM
Bolts seem to be just as tight as last night, so maybe I didn't tighten them up enough from the beginning.
I'll continue to check periodically.
