Old 03-03-2016, 08:56 AM #16
Binjinh's Avatar
Binjinh Binjinh is offline
Real Name: Ben
Binjinh is on a distinguished road
Binjinh's Avatar
Real Name: Ben
Originally Posted by LTDSC View Post
Is that a ground I see on the sub dash? You can do better than that come on ;)
Professional Installer
City Bound 2003 Limited 4.7
Binjinh is offline   Reply With QuoteReply With Quote
Old 03-03-2016, 08:58 AM #17
Binjinh's Avatar
Real Name: Ben
Binjinh's Avatar
Real Name: Ben
Originally Posted by 03BlueRunner View Post
Yes, I may be calling it the wrong thing, but on my 03 Sport V8, that button disengages the front drive wheels.
That button does not disengage wheels AFAIK, at least it isn't supposed to.
Old 03-03-2016, 09:35 AM #18
awdjunkies's Avatar
awdjunkies awdjunkies is offline
awdjunkies is on a distinguished road
awdjunkies's Avatar
Originally Posted by techno View Post
There is no 4 high disable button. There's a rotary switch on the V6 models to go from 4wd to 2wd.... What exactly did you press? Was it this?
Correct, That is the Center Diff Lock button.. To lock the center diff and make your awd a true 4wd
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
awdjunkies is offline   Reply With QuoteReply With Quote
Old 03-03-2016, 10:25 AM #19
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
I can attest to LTDSC's write up that his one wire hook-up between the factory modded button to the 4x4 computer works great! Muuuuch more simple than most are thinking...I'm glad I have this function now!
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 03-03-2016, 11:06 AM #20
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
I don't even know what it's for anymore haha I need to change it.
LTDSC is offline   Reply With QuoteReply With Quote
Old 03-03-2016, 12:37 PM #21
03BlueRunner's Avatar
03BlueRunner 03BlueRunner is offline
03BlueRunner is on a distinguished road
Learned something new - Thanks for the info! I was going off the icon on the button and assuming, but this thread made me break out the owner's manual and learn a thing or two
03BlueRunner is offline   Reply With QuoteReply With Quote
Old 03-04-2016, 05:45 PM #22
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
@03BlueRunner you're not the first person to mistake the meaning of that icon, it is only easily and correctly interpreted by those who are familiar with the mechanics and drivetrains of 4wd systems.
The x in the pic is to signify that the function of the center differential has effectively been removed.
techno is offline   Reply With QuoteReply With Quote
Old 03-05-2016, 06:58 PM #23
bantis556 bantis556 is offline
bantis556 is on a distinguished road
Where is the write up for the mod using the factory switch?
I did the mod by cutting the wire and adding a switch but I'd like it better if I could keep Atrac on the whole time. I've also noticed a decrease in power with my current mod.
2007 4runner Sport - V6 4x4 - HCF delete - Geolander AT's - H9 mod
bantis556 is offline   Reply With QuoteReply With Quote
Old 04-04-2018, 12:41 AM #24
sbitter sbitter is offline
sbitter is on a distinguished road
this has been covered hundreds of times. And you're wrong, i had a plug on my left side. Your model may not have, but it does exist.
I did this same mod, using OEM Trac Off button and wiring to the 4x4 module. I only have the VSC off light as well. Also it doesnt have an issue if i forget to unclick the button at turn off.
Do you have a write up and photos or anything you could send me? I'm looking to do this but I honestly haven't ever messed with electrical. I have been a motor guy always
Sent from my SM-G892A using Tapatalk
sbitter is offline   Reply With QuoteReply With Quote
Old 04-04-2018, 10:43 AM #25
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
http://www.toyota-4runner.org/2266263-post872.html
Old 04-05-2018, 05:14 PM #26
Zeke588's Avatar
Zeke588 Zeke588 is offline
Real Name: Zeke
Zeke588 will become famous soon enough
Zeke588's Avatar
Real Name: Zeke
Do you know if this would work on an 03 v8 limited?
03 V8 limited. Bilsteins, rear OME 895e springs. 285/75/16 Nitto Terra Grapplers Tacoma Wheels.
1993 4runner 3 inch lift 33/12.5/15 KO2 SOLD
Zeke588 is offline   Reply With QuoteReply With Quote
Old 04-05-2018, 05:55 PM #27
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
mine is an 03 V8 Limited
Old 09-23-2020, 05:35 PM #28
volkinator volkinator is offline
Real Name: Eric
volkinator will become famous soon enough
Real Name: Eric
Alright, sorry to resurrect this thread, but had a question. Wanted to do this with either the factory switch or just a toggle to ground, but you mention make sure to put it back to normal before turning off the truck... what happens if you don't? And is this something that you can toggle pretty much any time; ie press button/VSC off, press button again/VSC on? Just don't want one that you have to turn the car off and on, etc
Thank you for your contributions to the forum though! Lot's of good information!
2000 Limited | e-locker | 33's | Skids/Sliders | TRD SC | Sold
2007 Limited | V8 | RCI | OME 884/895e | 255/75r17 | JBA's
volkinator is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 11:55 AM #29
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
it just blinks, ive done it numerous times. It will blink until you flip the switch then itll go back to normal.
Old 09-28-2020, 01:29 PM #30
Real Name: Eric
Real Name: Eric
AWESOME! Glad it's nothing serious. Thanks for the answer!
Traction Control Go-T4R 4th Gen T4Rs 10 07-08-2014 03:16 AM
Traction Control shadyluke 3rd gen T4Rs 4 01-13-2014 08:26 PM
traction control and stability control cmills 5th gen T4Rs 7 02-07-2011 11:28 PM
Traction Control Jhamblett 4th Gen T4Rs 2 01-12-2011 11:35 PM
traction control DesertBelg 4th Gen T4Rs 1 04-01-2008 09:41 AM
