V8Man
BlackWorksInc
gm350reratliff
, Thanks for the info and suggestions.
I checked the dash and didn't see any extra wires or an alarm brain. I did disconnect any extra wiring on the battery to eliminate add-ons (winch,sub amp,compressor).
Last night I had several issues back to back which is odd considering but everything worked fine today.
As I have time I'll start checking grounds but I'm not sure where to start at this point. As for the fuse connections, I confirmed each connection seemed firm when checking the fuses but I will also see about accessing the rear of the fuse panel.
Again thanks for the input and I will update everyone as I have time to proceed. I'm hoping the extra wiring is causing issues and it will be a simple process of elimination.
2019 TRD Off Road Premium / Cordfed 2/1
2003 Limited V8 / Icon all around
/ Spidertrax 1.25"
/ BFG A/T KO2 SOLD
2004 SR5 4WD Sold
2002 Limited 4WD Now the daughters
