Old 03-09-2016, 03:36 AM #1
ghs215 ghs215 is offline
ghs215 is on a distinguished road
Question Front Lower Control Arm Bushings
I was told by the alignment guys that I need to replace the 2 bushings on the front lower A-Arm. Said there was excessive play and barely got it aligned.
I am reading through the shop manual and the Haynes. Seems pretty straight forward. I need to know 2 things:
1) What type of bushings should I buy?
2) Do I need a special tool to remove and insert the bushings? The shop manual says use SST and Haynes says take it to a shop. I am pretty good at red-neck rigging, so if there is a way, I'm game.
Thanks for your help!
2006 4Runner SR5 4x4 V6 Shadow Mica => Mrs
2006 4Runner SR5 4x4 V6 Titanium Metallic => Mr
2012 Sequoia SR5 RWD 5.7L Magnetic Gray Metallic => "I get to drive it! (says hubby) No! I get to drive it! (says wife) Happy Wife - Happy Life
ghs215 is offline   Reply With QuoteReply With Quote
Old 03-09-2016, 04:29 AM #2
dkyleb's Avatar
dkyleb dkyleb is offline
Real Name: Kyle
dkyleb is on a distinguished road
dkyleb's Avatar
Real Name: Kyle
These aren't as easy as they sound. I suggest using Moog replacements, some will suggest poly bushings. Anyways, here's some reading material from my adventure into this subject.
front LCA removal & bushing replacement - Toyota 120 Platforms Forum
https://www.tacomaworld.com/threads/...-press.134846/
https://www.youtube.com/watch?v=JZ5BMfkuHlM
dkyleb is offline   Reply With QuoteReply With Quote
Old 03-09-2016, 09:49 AM #3
IOPturbo IOPturbo is offline
IOPturbo is on a distinguished road
You need a press to remove the bushings and they will probably need to be persuaded with a torch. you can put a bottle jack in the arm as a way of jury rigging to get them out. I did mine last year and they were a PITA to get out. I went with Moog on mine.
IOPturbo is offline   Reply With QuoteReply With Quote
Old 03-10-2016, 11:49 AM #4
sprygsxr sprygsxr is offline
sprygsxr is on a distinguished road
Not sure if this was the right move but my lower ball joint and bushings weren't looking too good so I just bout these. Seem to be holding up with just a few thousand miles on them so far.
2004 Toyota 4Runner Front Lower Control Arm with Ball Joint Pair at 1A Auto.com
sprygsxr is offline   Reply With QuoteReply With Quote
Old 03-10-2016, 12:28 PM #5
Morphyne Morphyne is offline
Morphyne will become famous soon enough
Wow this is awesome. $237 for a complete set of upper and lower control arms. I just price moog ball joints and bushing and it was gonna run $202 on rock auto. Throw in the price of a torch and your are literally saving $10 to try and DIY this.
Morphyne is offline   Reply With QuoteReply With Quote
Old 03-10-2016, 12:43 PM #6
shahsmerdis shahsmerdis is offline
shahsmerdis is on a distinguished road
Doesn't even show a brand name?
I doubt these will last.
2004 limited V8
2002 SR5 V6
shahsmerdis is offline   Reply With QuoteReply With Quote
Old 03-10-2016, 12:56 PM #7
anyone have experience with these?
Detroit Axle - Both (2) Front Lower Driver & Passenger Side Control Arm and Ball Joint Assembly - 10-Year Warranty
by Detroit Axle
Link: http://amzn.com/B01ACJNRQM
Old 03-10-2016, 01:13 PM #8
daka320's Avatar
daka320 daka320 is offline
daka320 is on a distinguished road
daka320's Avatar
I currently have just over 200k and finally need some lcas. I've read several threads on this and other websites, and asked around. What I am hearing is that you are better off going with the Toyota lcas. They are more expensive but you will be replacing the other brands in a year or two. I would appreciate any comments and experiences on this since they need to be replaced. Also, if you are not diy, than it is about the same price to buy the whole control arm then just the bushings. I guess labor to replace the bushings makes the difference.
Also, Mike at Camelback Toyota sent me a quote. New lcas are $270 each. With all of the hardware is $658.00 plus tax. See pdf. Sorry it is sideways.
--<2004 4x4 Sport V6: FJ Springs and Bilstein 5100's All Around, Hidden Hitch Receiver, B&M 70264 Transmission Cooler, Weathertech Floormats, Brake Line Mod, Sway Bar Mods, Tekonsha Brake Controller and Dual Outlet Ashtray.
2014 Eclipse Evolution T225: Our house on wheels!
daka320 is offline   Reply With QuoteReply With Quote
Old 03-10-2016, 01:25 PM #9
considering the price difference I think it would make more sense just to have to replace them every few years. I mean if you have 200k miles on your rig and you get three more years our of a $150 pair of LCAs, I think you are doing good.
Old 03-10-2016, 01:36 PM #10
isdriven's Avatar
isdriven isdriven is offline
isdriven is on a distinguished road
isdriven's Avatar
Unless you are going to upgrade to ply bushings, do yourself a favor and buy the complete LCA assembly.
Having just done this, swapping the bushings is a real pita if you don't have the right tools. Most of the time the cam bots are seized and have to be cut out. You will need a touch, vice, bottle jack, and installation tool (get the 11pc Kit, the 9pc kit will not work) A shop press with the right sized press rings is incredibly helpful for this job. The torch is your friend! good luck!
05 Sport V8. Fj coils w/5100 @2.5" Front, OME 896 w/ 5100 Rear, Spidertrax 1.25", 285/65/17 Cooper Discovery AT3, 5th gen brakes w/ SS lines, Rebuilt LCA's w/ Whiteline Polys and Moog greasable cam bolts, Icon UCA's w/ custom dust covers, F&R Addco sways w/poly bushings, Volant intake, URD maf cal., Air injection delete kit. Magnaflow Y-pipe w/high flow cats, Magnaflow dual-exit catback, Diff breather relocated, VSC kill switch, Fog light switch mod, and rust....lots of rust.
isdriven is offline   Reply With QuoteReply With Quote
Old 03-10-2016, 01:37 PM #11
Exactly how I look at it. Toyota wanted something like 2k, if i end up doing it for 700 dollars. not dealing with pressing out old bushings, direct replacement getting done in half the time is a pretty good compromise.
I guess you also need another 100 dollars for alignment.
2004 limited V8
2002 SR5 V6
Old 03-10-2016, 10:11 PM #12
daka320's Avatar
daka320's Avatar
I understand where you are coming from. But, the labor has a lot to do with it also. The cheapest I have been quoted, and trust is $450. I would tempt a diy project but I just do not have the time and it is a dd for my wife. We plan on keeping it for another 150 to 200k miles. Give it to the kid when he starts driving in a few years.
Considering replacing the ucas also while it is torn apart, depending on the price though. Any help and information would be appreciated on those also.
Old 03-10-2016, 11:14 PM #13
NinjaOne's Avatar
NinjaOne NinjaOne is offline
NinjaOne will become famous soon enough
NinjaOne's Avatar
I had two separate mechanics look at mine and both recommended arm replacement rather than pressing out the bushings and replacing. Granted, if I had done it myself it would've been far cheaper to do bushings vs. new arms. Regardless, unless you have a lot of patience replacing the entire arm is prob. your best bet.
Just had uppers and lowers replaced by a dealer + misc mounting hardware. Here is part and price list to give you an idea. 95% covered under an extended warranty I purchased with my 4Runner.
You could save a lot by doing the labor yourself, supposed to be moderately easy. If planning on doing UCAs I would do aftermarket. LCA OEM
<a href=https://www.instagram.com/t4r_juan/ target=_blank>t4r_juan</a>
NinjaOne is offline   Reply With QuoteReply With Quote
Old 03-11-2016, 01:31 PM #14
Drunner97's Avatar
Drunner97 Drunner97 is offline
Real Name: Danny
Drunner97 will become famous soon enough Drunner97 will become famous soon enough
Drunner97's Avatar
Real Name: Danny
Dig around, @t-man posted a link that's the lower arms with bushings and ball joints installed and tie rod ends for like 200. I have it book marked at home for when I get around to doing it but not here at work and can't currently find the link.
build thread: https://independentoffroading.com/in...xit-thread.30/
IG: @4runner_doa
Drunner97 is offline   Reply With QuoteReply With Quote
What's the long term consensus on poly front upper/lower control arm bushings? goodgnus 3rd gen T4Rs 6 01-02-2016 02:25 PM
Lower Control Arm Bushings? Funcrazy1 3rd gen T4Rs 16 05-14-2015 09:01 PM
95 4x4 upper & lower control arm bushings replacement HELP!!! and rear bushings??? mark808 Classic T4Rs 18 07-08-2013 01:11 AM
Lower control arm bushings blue4r 3rd gen T4Rs 4 05-01-2013 04:04 PM
Lower control Arm Bushings gmata 3rd gen T4Rs 2 11-08-2011 08:10 AM
