Originally Posted by ddnww
Short answer
nope
nope
and nope
Reviving a four year old thread! (For those who are doing a Toytec lift now)
I recently finished installing the Toytec 1” body lift on my 2004.
I don’t have an issue with bumper separation, and I haven’t had to install the steering spacer (yet), but I did need to use the radiator brackets to move the radiator down an inch. The fan blades were hitting the fan shroud, and I didn’t want to trim the shroud where the fan was hitting it.
Update: my steering is a little stiff after the body lift. The steering shaft is rusty at the joint between the upper and lower steering shaft, and did not move when I loosened the nuts under the hood. If I can somehow extend the effective length of the steering shaft, I may get rid of my steering stiffness without needing the steering spacer.
