Old 08-11-2006, 10:58 AM #1
ice's Avatar
ice ice is offline
ice is an unknown quantity at this point
ice ice is offline
ice's Avatar
Stuck bolt-need help!
Hi, I need to remove 4 bolts to install my Jaos skid plate, but one of them got stuck(probably from the impact of off roading), I have tried BP Blaster, WD-40 but no luck.
I have found this thread
http://www.toyota-4runner.org/showth...ght=stuck+bolt
and has mentioned the "Lisle 6 pc. Stuck Bolt, Nut and Stud Remover Set" and "Craftsman Bolt-Out
Stuck bolt-need help!-bolt-jpg
2014 TE White Premium KDSS
2004 SR5 V6 4WD Titanium - Sold
ice is offline   Reply With QuoteReply With Quote
Old 08-11-2006, 11:54 AM #2
darkmark darkmark is offline
darkmark is an unknown quantity at this point
Have you tried using a (propane) torch on it yet? The idea is to heat up the setting where the bolt is contained (and not the bolt) so the bolt cools faster than the setting (ie the setting is expanded) so the bolt can be removed.
(!wired) ? (coffee++) : (wired);
darkmark is offline   Reply With QuoteReply With Quote
Old 08-11-2006, 02:43 PM #3
Bluto's Avatar
Bluto Bluto is offline
Bluto is on a distinguished road
Bluto's Avatar
Heat with a propane torch. Then spray with non-flam liquid wrench. Repeat a few times.
You can also try a breaker bar or impact wrench. But if you break off the bolt, you have more problems.
Bluto is offline   Reply With QuoteReply With Quote
Old 08-11-2006, 02:57 PM #4
toybox's Avatar
toybox toybox is offline
toybox is on a distinguished road
toybox's Avatar
I'll agree with using heat to get this bolt out. In my experience if I couldn't get it out with Liquid Wrench then the propane torch came out and always did the trick.
Joe l 2003 V8 Sport 4x4
Titanium Silver
toybox is offline   Reply With QuoteReply With Quote
Old 08-11-2006, 04:20 PM #5
Jay's Avatar
Jay Jay is offline
Jay is an unknown quantity at this point
Jay Jay is offline
Jay's Avatar
I have a set of the Craftsman Bolt Out set, and it works wonders. Its a tool that every mechanic should own. Stripped bolts are a thing of the past, the more torque you apply to the bolt, the more it bites and grabs to remove the failed bolt. I had a bolt on the back of the engine block of my old car that was stripped, it w as a header bolt, tried every method under the sun and no luck. Got the tool, and in about 3 minmutes i had the bolt off and thrown across the garage, lol.
2001 4Runner SR5 4WD
http://i44.photobucket.com/albums/f2/r1eger/fotr.jpg
Jay is offline   Reply With QuoteReply With Quote
Old 08-11-2006, 11:45 PM #6
mikes4runner's Avatar
mikes4runner mikes4runner is offline
mikes4runner is on a distinguished road
you did not say that the head was stripped right?
Did you try a breaker bar?
I have one that I have know idea what it went too but it slips over the handle of my socket wrench and will work everytime.
Mike
01 MR2,96 Vette,93 4runner
mikes4runner is offline   Reply With QuoteReply With Quote
Old 08-12-2006, 11:50 AM #7
X6RUNNER X6RUNNER is offline
X6RUNNER is an unknown quantity at this point
The bolt head appears to be slightly stripped. "Craftsman Bolt-Out" will get it out in no time, and it's a much have tool for any DIY mechanics. I was lucky to get a set from Sears last year for $10 Bucks. Good luck
2006 V8 SPORT EDITION 4X2
X6RUNNER is offline   Reply With QuoteReply With Quote
Old 08-13-2006, 04:56 AM #8
Bouncnb Bouncnb is offline
Bouncnb is an unknown quantity at this point
If the bolt isn't too bad and you can use a breaker bar, try putting a cheater bar/pipe on the end of it for more leverage. Get some kind of heavy pipe and slip it on the end of the breaker bar. That helped me when I had to pull of a crank pulley that was stuck.
Bouncnb is offline   Reply With QuoteReply With Quote
Old 08-14-2006, 12:45 AM #9
Spider5's Avatar
Spider5 Spider5 is offline
Spider5 is an unknown quantity at this point
Spider5's Avatar
Have you tried a pnuematic wrench? It should take most bolts off pretty easily. As an example; I had no problem with the exhaust bolts with pnuematics where other had major hangups as reported on T4R.
'05 SE 4x V8
Spider5 is offline   Reply With QuoteReply With Quote
Old 08-14-2006, 08:29 AM #10
Koz's Avatar
Koz Koz is offline
Koz is on a distinguished road
Koz Koz is offline
Koz's Avatar
You need to get some WD or screw loose on the treaded part of the bolt. Try to stick your arm in from the side and spray. Let it soak in and then try to get a Craftsman Bolt Out socket and impact gun/breaker bar on it. If all else fails you could grind off the head and grab the stub with vise grips or grind flush and drill out the bold and maybe chase the treads. The final solution would be to drill out a bigger hole and put a bigger nut/bolt.
Koz
Stuck bolt-need help!-bolt-out-jpg
Koz is offline   Reply With QuoteReply With Quote
damaged bolt or pan sleepy88 Classic T4Rs 2 02-15-2009 02:44 PM
Stuck intake bolt the_dingman Classic T4Rs 2 01-11-2008 08:34 AM
Good news - skid plate arrived! Bad news - missing bolt dingo Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-13-2005 06:41 AM
The secrets of bolt tightening Thai Maintenance/Detailing 15 03-06-2004 12:14 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
