Originally Posted by cools20
this is nice to know! hate when this kicks on when I'm in the desert or wheeling.
A ZPC is not going to keep your VSC from kicking on when driving out in loose dirt/gravel or wheeling.
A ZPC will NOT completely eliminate the possibility of VSC kicking on when taking a sharp turn quickly in a lifted truck.
The VSC/ABS system in these trucks is surprisingly sensitive, and it will kick in if it reads significant enough variance in rotational velocity from one wheel to another. Larger tires with more sidewall flex, lifted suspension that moves and shifts more under certain loads and during directional changes (i.e. sharp turns over uneven pavement, at high enough speed) WILL result in a short term variance of rotational velocity between your wheels. More-so than what existed in the stock/OEM vehicle configuration. ABS system interprets that variance as wheel slip, and applies VSC correction to fix it.
2 Ways around it.
-Disable VSC.
-Pay attention to the conditions when VSC kicks in, and modify your driving style to avoid them. Maybe don't take certain turns as sharply or quickly.
