Real Name: Ron
Real Name: Ron
Originally Posted by dkyleb
100% sure about this? I know some lights come on, but do all of them?
Is there any way to confirm that VSC is actually off?
From the 2005 owners manual (page 152).
(j) “VSC TRAC” Warning Light
The light warns that there is a problem
somewhere in the following.
Vehicle stability control system
Traction control system
(two−wheel drive models)
Active traction control system
(four−wheel drive models)
“AUTO LSD” system
Downhill assist control system
Hill−start assist control system
The light will come on when the ignition
key turned to “ON”, and will go off after
a few seconds.
Can't help you with determining if VSC is on/off without the light working, other than driving aggressively on a slick parking lot and seeing what happens.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
