Originally Posted by JeffMerr
Is the easiest way to flush it to suck out the fluid from the reservoir and put the same amount back in? I'm guessing 3 times or so?
Suck the fluid out of the reservoir, remove it and clean it out, more than likely it will look bad color and that will tell you.
Reinstall and leave the return line off and put in a drain bucket. Fill the reservoir up, and slowly turn your steering left then right, keep an eye on reservoir and keep it full. When fluid is coming out all clean, button it back up and top off.
Run the vehicle so it can pump out the air in the system.
