Finally Fixed that Damn Poping Noise!!!
So while doing an oil change and looking for a leak, I noticed one of the bolts for the power steering rack was loose. I could turn it by hand. I have had the front end pop for a while, but it would only happen every once in a while, and then it started doing it every time I went around a corner. I tightened both bolts on the rack, and took it for a spin. No more pop! I hope this helps anyone who has had the same issue and couldn't find it. I also cleaned and greased the sway bar bushings, so I think it was a combination of both things. She has 161,000 on her and still solid and running strong.
