Originally Posted by svana
I love the clearance of the 4x4 rears, but I'm in agreement in not wanting to cut my rear frame. If it wasn't the case I'd sell my cbi rear in a heartbeat to switch.
In order to use his bumpers you have to cut it off. And with his bumper, it now has a new cross member in it's place. A lot stronger ( 2x2, 1/4" thick) that give it support.
Originally Posted by Inv4drZm
You have to cut a little more than that off, the 2 main frame sections, you have to cut off 3" from the end also. This is why it hugs the body so tight and gives it so much departure clearance also.
Originally Posted by unevolved
Are there any good rear bumpers out there that work with the V8 hitch? I tow with my truck occasionally, and I'm not willing to give up the heavy duty hitch. The CBI one looks like it requires removing the hitch and using theirs.
These bumpers bolt onto the same holes as the HD hitches do. The receiver is welded into the new 2x2 cross member and the exterior shell.
Let's just add this, I have a 7k tandem axle flat bed, and a slant 2 horse trailer that I occasionally pull with mine also.
