Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 06-20-2016, 04:08 PM #16
absalom's Avatar
absalom absalom is offline
Real Name: Jordan
absalom has a spectacular aura about absalom has a spectacular aura about
absalom's Avatar
Real Name: Jordan
Originally Posted by Arthur4R View Post
@absalom ericthecarguy did a flush with engine on and turning the wheel lock to lock. He has it on youtube and he did not have to lift vehicle. Any reason you went with a method that requires lifting the car and not turning it on? I am looking to do it and trying to figure out the easiest best way to do it. Also how many quarts did it require? I purchased 2 quarts of Toyota transmission fluid hoping it will be enough.
Turning the wheels with the car stationary puts a large strain on the power steering components, and dulls the feedback during the procedure. With no weight over the front wheels, I can feel exactly how much resistance is encountered during the bleeding.
You can do it with the truck on, on the ground. You could do truck in the air, engine off. You can mix and match however you like. I just find this way to be gentlest on the PS components, while providing valuable feedback as to my progress.
If you don't have a floor jack yet, you could do it his way. But then I'd ask, why don't you have a floor jack yet, that's of greater concern to me.
absalom is offline   Reply With QuoteReply With Quote
Old 06-20-2016, 04:45 PM #17
Arthur4R's Avatar
Arthur4R Arthur4R is offline
Arthur4R is on a distinguished road
Arthur4R's Avatar
Thanks, how many quarts did you use?
2021 4Runner Limited
2018 4Runner Trd Off Road kdss SOLD!
Arthur4R is offline   Reply With QuoteReply With Quote
Old 06-20-2016, 05:02 PM #18
absalom's Avatar
Real Name: Jordan
absalom's Avatar
Real Name: Jordan
I don't recall, but I believe I bled out about two. I just bought a gallon, so I'd have plenty on hand in case it took more to fully bleed the lines.
Old 06-21-2016, 08:35 PM #19
Arthur4R's Avatar
Arthur4R's Avatar
Did the power steering flush today, I have to say every one should go do it right now!!!!! What a difference in the steering wheel feel, it has lighten up a lot. I was wondering why it was so stiff
2 quarts of oil was more then enough, after about 3/4 quarts I noticed pink started to come out.
Old 06-22-2016, 12:40 PM #20
The Yin's Avatar
The Yin The Yin is offline
The Yin is on a distinguished road
The Yin's Avatar
Aft?
So, I'm I understanding correctly that we use Auto Tranny fluid in our 4th Gen Power Steering system??
If so, what would you recommend for that?
When I search "toyota power steering fluid" on amazon the first item that shows is Toyota Genuine Fluid 00718-ATF00 Dexron III Transmission Fluid.
-The Yin
2005 T4R Sport V6 2wd
The Yin is offline   Reply With QuoteReply With Quote
Old 06-23-2016, 12:31 PM #21
Arthur4R's Avatar
Arthur4R's Avatar
This is what I used, manual states automatic transmission fluid, I went down to my local dealership and they gave me these bottles.
Old 06-23-2016, 02:38 PM #22
poncharello poncharello is offline
Real Name: Brett
poncharello is on a distinguished road
Real Name: Brett
It's there any difference between those two? They look like they're the same thing with an added "type" on the label.
- Brett
2008 V8 Limited
poncharello is offline   Reply With QuoteReply With Quote
Old 06-30-2016, 03:39 PM #23
Rdf5186 Rdf5186 is offline
Rdf5186 is on a distinguished road
Does it matter what kind of fluid I use. In particular can I just go to autozone and get and atf dextron III for the flush
Rdf5186 is offline   Reply With QuoteReply With Quote
Old 06-30-2016, 05:07 PM #24
mizak82 mizak82 is offline
mizak82 is on a distinguished road
Does this work?
2007 Toyota 4runner Sport Edition 4x4, 15% tint, 1.5 inch ALL PRO spacers, de badged, Full interior LED swap (cluster, hvac, etc), plastidip wheels, blacked out headlight housing, K&N, smoker kit, carbon fiber shifter knob, carbon fiber interior wrap, diff breather mod, added VSC off mod, added Compass rearview mirror, independent fog lights, DTRL delete, zXe bulbs, Jensen VX7022 NAV head unit, back up camera, custom rear storage
mizak82 is offline   Reply With QuoteReply With Quote
Old 06-30-2016, 07:15 PM #25
Yep.
That does. Just trying not to go to the dealer.
Old 07-01-2016, 08:12 AM #26
ben550's Avatar
ben550 ben550 is offline
ben550 is on a distinguished road
ben550's Avatar
I did this using your method a year or so ago... Worked well. I used Valvoline ATF. I believe it was 2 quarts total. I bought three and have an extra on the shelf.
DIY: Power Steering Flush (4th gen specific)-67898fd6-ff8e-4d2a-be77-88215d75f646_1-3f72b10077b1a5cb2b5945f7e859012a-jpeg
'01 SR5 3.4 V6 4WD
'04 SR5 4.0 V6 2WD
'07 Tacoma 4.0 V6 4WD
'06 Sport 4.7 V8 4WD
'10 Limited 4.0 V6 4WD
ben550 is offline   Reply With QuoteReply With Quote
Old 07-01-2016, 08:49 AM #27
Thanks. That is what I was looking for
Old 08-21-2016, 08:12 PM #28
smokey7722's Avatar
smokey7722 smokey7722 is offline
Real Name: Adam
smokey7722 is on a distinguished road
smokey7722's Avatar
Real Name: Adam
Just did this today using this Pennzoil ATF Dex/Merc oil. As @Arthur4R said by about 3/4 of a quart it was nice and pink coming out. I used a little more than a single quart and probably have 3/4 of the other one left. I was going to take the reservoir out to clean it but given the rust (used to be an east coast truck) I didn't want to chance removing the bolts and I didn't bother spending a ton of time playing with the metal clip that looked like it held the plastic reservoir in place. I'll just keep an eye on it and flush it again in the future.
No HUGE noticeable difference though in driving/steering to be honest. What came out was basically sludge though so I am sure that once the new oil gets more time to cycle through the system it will clean it up a bit more.
Thanks for the writeup!
2005 V8 Sport Edition 4x4 | Icon Stage 2 | Total Chaos LCA's | Blackvue DR900X-2CH Dashcam | Pioneer AVIC-W8600NEX
smokey7722 is offline   Reply With QuoteReply With Quote
Old 08-22-2016, 01:14 AM #29
smokey7722's Avatar
Real Name: Adam
smokey7722's Avatar
Real Name: Adam
Quick update - while steering isn't easier or smoother I have noticed that it is MUCH more sensitive. The 1" of play or so I had previously is no longer and is now sensitive at all times to movement. So definitely an improvement with the flush!
Old 08-22-2016, 09:33 AM #30
Morphyne Morphyne is offline
Morphyne will become famous soon enough
I have a half jug od valvoline maxlife in the shop. I am assuming that would work in this situation?
Morphyne is offline   Reply With QuoteReply With Quote
Is a Power Steering Flush necessary??? Trdsupranick 4th Gen T4Rs 43 11-08-2015 05:11 PM
power steering flush dd210 3rd gen T4Rs 2 10-17-2011 08:29 AM
03 Power Steering Flush? bowhunter53 4th Gen T4Rs 2 10-24-2008 08:07 PM
