Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 08-22-2016, 10:11 AM #31
Arthur4R's Avatar
Arthur4R Arthur4R is offline
Arthur4R is on a distinguished road
Arthur4R's Avatar
I highly suggest using Toyota transmission fluid for the flush. On Honda's if you use other fluid then oem steering components start to fail. The quart of Toyota fluid is inexpensive I think $10-$12 a quart. Some will notice more improvement then others probably do to when it was changed out last time. My fluid most likely had 160k miles on.
2021 4Runner Limited
2018 4Runner Trd Off Road kdss SOLD!
Arthur4R is offline   Reply With QuoteReply With Quote
Old 08-22-2016, 05:23 PM #32
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
just an addition to your diy.
1. remove the oil from the reservoir
2. disconnect both connection
3. remove the reservoir
4. clean it up.
this way, you'll know if your new oil is becoming dirtier again. that's what I did.
radlynx is offline   Reply With QuoteReply With Quote
Old 08-22-2016, 07:32 PM #33
smokey7722's Avatar
smokey7722 smokey7722 is offline
Real Name: Adam
smokey7722 is on a distinguished road
smokey7722's Avatar
Real Name: Adam
4. clean it up.
Did you release the metal clip to slide the reservoir out or did you remove the 3 bolts on the metal framing holding it to remove it? I haven't loaded up alldata to look at for any official docs on the removal but from looking at it it looked like those were the two options. The bolts on mine are pretty solid based on rust and I didn't want to bend the metal clip too much.
2005 V8 Sport Edition 4x4 | Icon Stage 2 | Total Chaos LCA's | Blackvue DR900X-2CH Dashcam | Pioneer AVIC-W8600NEX
smokey7722 is offline   Reply With QuoteReply With Quote
Old 08-22-2016, 09:19 PM #34
JeffMerr's Avatar
JeffMerr JeffMerr is offline
JeffMerr is on a distinguished road
JeffMerr's Avatar
How many quarts are needed?
2009 Trail Edition
2006 Sport Edition - SOLD
JeffMerr is offline   Reply With QuoteReply With Quote
Old 08-22-2016, 09:21 PM #35
Arthur4R's Avatar
Arthur4R's Avatar
1 quart is enough, after 3/4 if the quart you start seeing pink fluid coming out. I used 1 1/4 quarts to do it I easily could of done it with 1 .
Old 08-27-2016, 11:29 AM #36
Morphyne Morphyne is offline
Morphyne will become famous soon enough
Just finished up on my t4r and gx. I spilled most of my old reservoir fluid. I would recommend hang some kind of plug ready when you do this. Also when you are done you need to start the engine and give it. A few turns. I took my t4r for a test drive and thought I broke somethi ng bc the ps pump was whining. Added more fluid and now it's good.
I can say after 170k on the old fluid the steering feels better.
Morphyne is offline   Reply With QuoteReply With Quote
Old 08-29-2016, 03:38 PM #37
Registered User
Registered User
you'll need at least 2 quarts.
Old 08-29-2016, 03:41 PM #38
Registered User
Registered User
I actually don't remember how I removed it. all I remember, I took it out, cleaned up the gunk inside until it's squeaky clean.
Old 08-29-2016, 04:08 PM #39
I needed exactly 1 quart. 3/4 quart until it runs pink and then the rest when you start the truck and it sucks down a bit.
Old 09-07-2016, 08:31 PM #40
S Brake's Avatar
S Brake S Brake is offline
S Brake is on a distinguished road
S Brake's Avatar
I did this today, my fluid was nearly black. Super easy process.
S Brake is offline   Reply With QuoteReply With Quote
Old 09-08-2016, 01:46 PM #41
TrueBlue's Avatar
TrueBlue TrueBlue is offline
TrueBlue is on a distinguished road
TrueBlue's Avatar
Would Royal Purple ATF work for this? I assume any ATF that works for our transmissions would work for the power steering as well, considering the factory probably filled em with the same stuff
Sent from my SM-G935V using Tapatalk
TrueBlue is offline   Reply With QuoteReply With Quote
Old 09-08-2016, 02:19 PM #42
Hawaiian Hillbilly's Avatar
Hawaiian Hillbilly Hawaiian Hillbilly is offline
Hawaiian Hillbilly is on a distinguished road
Awesome thread! Imma get this done very soon on both my 4th gens! aloha, HH
Hawaiian Hillbilly is offline   Reply With QuoteReply With Quote
Old 10-02-2016, 08:34 PM #43
snowboardwcu snowboardwcu is offline
Real Name: George
snowboardwcu is on a distinguished road
Real Name: George
4. clean it up.
Followed instructions here and did the reservoir cleaning. Glad I did it, there was almost no fluid in reservoir and what I thought was fluid was caked on shit. Soaked it in gas for a few hours and mostly clean.
Steers like a new truck! Thanks.
snowboardwcu is offline   Reply With QuoteReply With Quote
Old 10-15-2016, 03:36 PM #44
Marfy's Avatar
Marfy Marfy is offline
Marfy will become famous soon enough Marfy will become famous soon enough
Marfy's Avatar
I did this today. I made a mess but what can ya do. Replaced it with dex 6. See how that goes...
[Sold] 2007 Limited - V8 4WD
Stock Rear RAS / Bilstein 5100s / OME 885 / RB 1.25 BL / BFG KO2s - 275/70R17 / SCS Ray 10 - Brushed Gold /
XenonDepot Hid Kit (lows) / Aftermarket Yellow Fogs w/ XenonDepot HIDs / DT Premium Long Tubes / Custom Y w/ 2 cats deleted / full custom exhaust pipe with magnaflow / aFe CAI / MAF Calbrator
Marfy is offline   Reply With QuoteReply With Quote
Old 12-08-2016, 06:25 PM #45
4thgenblake's Avatar
4thgenblake 4thgenblake is offline
Real Name: Blake Salce
4thgenblake is on a distinguished road
Can you elaborate step 9 a little more? And I only need 1 bottle of Dex 3 correct
_MURDERED_OUT_'06_
4thgenblake is offline   Reply With QuoteReply With Quote
Is a Power Steering Flush necessary??? Trdsupranick 4th Gen T4Rs 43 11-08-2015 05:11 PM
power steering flush dd210 3rd gen T4Rs 2 10-17-2011 08:29 AM
03 Power Steering Flush? bowhunter53 4th Gen T4Rs 2 10-24-2008 08:07 PM
