Originally Posted by skott
You reset the ECU when you unplugged the battery. The computer is having to relearn all the short term and long term fuel trims again. This is perfectly normal. I don't know how long you've let the engine run since this, but it usually clears up after letting it idle for about 20 minutes or driving it for a while.
If it persists after a few days, then you should start looking at other things, but odds are, if it ran/idled fine before the battery disconnect it'll fix itself.
I've only let it idle for about 30 seconds each time before driving, but I've already driven about an hour on it total but at higher speeds.
I'll keep that in mind though and if it doesn't go away in a few days I'll probably come back.
