05-28-2016, 01:04 PM
NO SPEEDO! Pulled P0500 Code...HELP!
So last night, some asshat decided to slam on his brakes on the freeway right in front of me. I slammed on my brakes, started to skid, truck got a little sideways, but ended up ok (no crash, just an angry horn and a middle finger from me to "DJ Brakes-a-lot").
Then, about a minute later, I realized my speedo stopped working. I stopped, turned the engine off, started her back up. Check engine light came on and threw a P0500. Still speedo isn't working.
I did some searching on here, and most of the results was that it started working randomly again. One was fixed with a "Dakota Digital."
I have the "Universal Speedhealer" waiting to be installed once my 35s arrive. Would installing this fix my issue?
Open for any help of feedback. Thanks!
05-28-2016, 04:18 PM
What did you use to pull up the code? Try removing negative terminal from the battery for an hour or two and see if that helps.
05-29-2016, 10:50 PM
@ ArthurHawk
I use a BlueDriver scan tool.
Disconnected the battery for 1.5 hours, hooked it back up and still no speedo.
Anyone else have any ideas? I really don't want to take it to Toyota.
05-30-2016, 10:06 PM
maybe it just a blown fuse, check the dome fuse or dimmer too.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
05-31-2016, 12:20 PM
Thanks
@ riceandpho
My dome and dimmer still work, so I am not sure that it would be a blown fuse. The code that pulled referenced a sensor. Is there a fuse that is associated with this sensor?
Does anyone know where this sensor is located?
Thanks again all!
05-31-2016, 01:48 PM
Check the VSS wire from the Skid Control ECU to the the combination meter.
Vehicle speed is collected via the wheel speed sensors, smoothed and converted into a single square wave, which is then output to the combination meter for the speedometer and then relayed to the ECM. I'm guessing the issue is between the skid control ECU and CM since the speedometer isn't registering.
05-31-2016, 05:18 PM
Thanks
@ BlackWorksInc
...now a stupid question, where would I locate the VSS wire from the Skid Control ECU to the combination Meter?
05-31-2016, 07:24 PM
Update!
So I just did a Zero Point Calibration of Yaw Rate (using paperclips) .
Here is what it did do:
Speedo is now working
Check Engine Light is off
Here is what it did not do:
Turn off my VSC on/off dash lights
I am hoping this is the final fix to my speedo issue, but will report back after a 100+ miles.
05-31-2016, 08:51 PM
Try to pull the code(s) again & reset them.
1999 BMW M3 coupe(E36) & 2005 V8 sport 4X4 black: ARB bull bar with 4 hella 500s,backup camera in spoiler,VSC off, springs:Tacoma w/ toytec(1/2"Fr) & FJ w/ daystar(1.5"R) spacers,Bora .75" front & Spidertrax 1.25" rear spacers,swaybar bushings upgrade,Stoptech rotors,SS brake lines,RCI Metalworks skids (front, trans.,transfer), Volant CAI,DT shorties w/ Dirty Deeds exhaust,fully soundproofed,Rostra seat heaters,HID (lows),HIR (highs),running board lights (added),aux reverse lights,2006+ tail lights,rear fog mod (tail, brake, directional OR rear fogs),Scion T1819,LED int. lights, key reminder diabled, Land cruiser steering wheel,rear window dog barrier, vent visors, Ultraguage, Enkei Deep Six 20" wheels for summer, factory sport wheels with A/Ts, FJ cruiser wheels with winter tires
06-01-2016, 12:31 PM
@ SSt4r
pulled my code(s) again and came up with a clean slate.
I still have the annoying Christmas tree dash. I know I need to do another brake bleeding to clear my "BRAKE!" (and possibly the ABS) dash light, but why wouldn't my VSC on/off lights not clear?
06-01-2016, 10:00 PM
Originally Posted by tmcintosh3
@ SSt4r
Attachment 206277
Your scantool doesn't do non-OBDII DTCs I am guessing. You should see a multitude of "C" codes stored if those lights are on.
06-01-2016, 11:17 PM
I do
@ BlackWorksInc
, a whole host of them
C1246 - This one I should be able to fix with a brake bleeding.
C1223 - I hope this goes away with the brake bleeding as well
C0210 & C0205 - I may have damaged the wiring or sensors during my lift and or brake/rotor replacement. Any ideas on a quick fix? or do I need to replace wiring/sensors?
08-19-2017, 06:19 PM
I had the p0500 code vehicle speed sensor on my 1996 4runner sr5 v6 automatic
Changed the vehicle speed sensor $20 - didn't help
Changed the combo meter /instrument cluster/ gauge cluster with one off eBay $60 - fixed it .
I made sure the new combo meter part number matched my old one also. Not sure if it matters because I noticed some meters in eBay looked exactly the same but had different part numbers .
Only my speedometer and odometer didn't work. And only check engine light was on unlike other members that had abs and other lights on
Hope that helps anyone with same issue .
01-23-2019, 06:39 PM
What was the final solution to this?
06-22-2019, 11:59 AM
@ tmcintosh3
how did this end?.what did you do that made the lights go away
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
