Originally Posted by 4thGen4.7
WS ATF is what I used. If I get a fresh fluid swap and my old fluid is thick and burnt and full of metal shards, hypothetically speaking, would my gears slip with all new fluid? This may just be an old wise tale though?
Ive done the fluid exchange on two 4runners... 04 V6 (136k miles at the time of exchange) and 06 V8 (165k miles at the time of exchange)
04 Had never had the fluid serviced. It was brown. No metal shavings, good amount of silt tho.
06 Did have transmission fluid serviced at around the 100k mark (documentation) however it had been serviced with non Toyota fluid which is why I did the exchange.
Both were high mileage. Neither had burned smell to them, or metal shavings. Both seemed to benefit from the service. Watching the fluid being pumped out of the return line into my bucket changing from brown to bright red was well worth the work.
If your transmission seizes up and wets the bed after a fluid exchange it was on its way out anyways and probably would have died regardless. I have not personally witnessed new fluid damage a transmission.
Definitely try to grease the drive shaft. That would definitely help the clunk.
