Originally Posted by BlackWorksInc
How are you reading your transmission temperatures? I know that ScanGauge can be a bit inaccurate from what I have heard.
I haven't had issues with my transmission cooler not being able to keep temperatures stable. But if you're doing a lot of slow crawling and such I wouldn't be surprised to see temperatures creep up a bit since airflow is lower.
Post Note-
Where in Oregon are you?
Yes, it was some very slow crawling. When i'm just driving down the road, even towing small loads it seems to do just fine. I suspect as well it's the lack of airflow, but i'm hoping that up sizing it will help, and if not I can at least fit a fan to push some air when crawling. The OEM one is so small it would be hard to mount a fan.
Honestly the temps never reached a bad point, they just started to crawl up there a ways and I am just super particular about everything being perfect and would rather be 100% safe then sorry.
BlackWorksInc
I live in Hillsboro, and went to shoot and play around up at Browns Camp area in Tillamook Forest.
