06-28-2016, 09:22 PM
Truck lift for your lifted truck
So I've only done a quick search but wanted a more recent option. Now that I have a 3 inch lift installed on my truck, I want a lift I can carry around with me in case I get a flat. I've heard that hi-jack lifts will not work on 4runner if it doesn't have either sliders or mod bumpers. So for those that have a lift installed minus the sliders or bumpers, what lift did you purchase. I know you can still use the factory lift on either a cinder block or 2x6 etc, but it seems like unnecessary stuff to carry around just for emergency purposes.
Any advice appreciated
2006 Sport Edition 4Runner
Toytec suspension
Total Chaos UCA
Spidertrax spacers
06-29-2016, 12:19 AM
I run 265/70/17 and used the stock jack for the rear. Never needed/thought about trying it for the front. I put it under the axle housing.
I haven't really looked for one either.
05' V8 4x4 230K LEVEL 8 MK6 wheels Grabber AT2
3.5"/2.5" lift 1/2" body lift Flowmaster 50 series
K&N filter with air box mods
Custom built roof rack
Satoshi grille
06-29-2016, 12:52 AM
Real Name: Kevin
Real Name: Kevin
You can use a hi lift without sliders or bumpers. Buy a Wheel Mate, or just loop a sturdy ratchet strap around the tire.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
06-29-2016, 10:01 AM
^^ That would work if your stuck, but if I have a flat it wouldn't really be useful. The tire I'm trying to take off is tied to the hilift or am I just missing something here.
06 Curry Runner
06-29-2016, 11:17 AM
How about a floor jack?
06-29-2016, 12:13 PM
Real Name: Ron
Real Name: Ron
For shop use, get a floor jack. Much safer than anything else.
Also get a pair of heavy duty jack stands (the tall, 6 ton kind, $50-60 at Harbor Freight or Autozone). They'll be tall enough to support the frame with your wheels off the ground and suspension at full droop. Again, you need these for safety.
For trail use, use the Wheel Mate to lift the flat tire with the Hi-Lift. Then bring along one of your jack stands to support the frame while you change the tire. Then use the Hi-Lift/Wheel Mate again to remove the jack stand and you're good to go.
Sure it's a bit of messing around, but it's safe.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
06-29-2016, 12:34 PM
Real Name: Kevin
Real Name: Kevin
No, you're right. Like Ron says, I carry a small jackstand.
I also carry a Bushranger exhaust lift, which is another option, though it costs a little more.
06-29-2016, 12:36 PM
Real Name: Ron
Real Name: Ron
I've considered getting one of those. How has it worked for you? Worth it? I'd appreciate a real-world opinion.
Thanks!
06-29-2016, 02:27 PM
Real Name: Kevin
Real Name: Kevin
I love mine. Much more stable than a hilift, and less effort to boot. Make sure you don't have an exhaust leak, and if you do then make sure you're carrying a legit air compressor. The Bushranger won't work if you have any kind of exhaust leak, and small compressors don't have the grunt to lift a heavy truck.
06-29-2016, 02:46 PM
2- 4"X4" wooden blocks and the stock scissor jack
08' 4Runner SR5 4WD V6 Level 8 MK6 wheels//Kenwood DDX9903s//JL 10W3v3 on 500/1//LEDs//ICON Ext Coilovers FR//Metaltech LT Rear Springs w/ Dobinson LT Shocks//JBA UCAs//spidertrax//5th gen brakes in front//295/70/17 Cooper Maxx//SS brake lines// http://www.toyota-4runner.org/4th-ge...ld-thread.html
06-29-2016, 04:24 PM
Real Name: Ron
Real Name: Ron
Thanks. May have to put one on the wish list.
06-29-2016, 04:27 PM
Real Name: Chris
Real Name: Chris
Me too, cheap & convenient.
Chris - '07 SR5
‘05 Limited - sold
06-30-2016, 09:50 AM
Thanks guys, I may give the Bushranger exhaust lift a try. Looks like it wouldn't take too much room.
Toytec suspension
Total Chaos UCA
Spidertrax spacers
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
