Old 07-09-2016, 09:32 PM #1
BCKGUY BCKGUY is offline
BCKGUY is on a distinguished road
Check engine, traction control, and VSC light on.
Made a Vlog on gas cap issue and check engine, VSC off, and traction control lights. Check it out: https://youtu.be/SGPMo3bRROE
Lights didn't go off immediately. Had to reset battery. Code reader from Autozone said likely culprit was gas cap. We shall see!
2008 4Runner Sport Edition
2015 4Runner SR5
GO BUCKEYES!!
BCKGUY is offline   Reply With QuoteReply With Quote
Old 07-10-2016, 01:01 AM #2
Arthur4R's Avatar
Arthur4R Arthur4R is offline
Arthur4R is on a distinguished road
Arthur4R's Avatar
I had the same issue, Replaced gas cap from Toyota and disconnected the battery for a day. Put everything back and no more lights. Drove over 1000 miles without an issue.
2021 4Runner Limited
2018 4Runner Trd Off Road kdss SOLD!
Arthur4R is offline   Reply With QuoteReply With Quote
Old 07-10-2016, 01:09 AM #3
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Next time I would post the DTCs you got as people will erroneously assume that all MIL, VSC, and TRAC warning lamp events are gas cap related (which is not to say they can't be, but it's an erroneous assumption).
Post Note-
Some members have had dodgy luck with non-factory gas caps not sealing correctly and have ended up going back to a factory one.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 07-11-2016, 10:50 PM #4
GoPats's Avatar
GoPats GoPats is offline
GoPats is on a distinguished road
GoPats's Avatar
Originally Posted by BlackWorksInc View Post
Post Note-
When mine had this problem, I got a new cap at Autozone (Duralast), and it felt really loose. The design of that cap, however, allowed me to make a modification that seems to be working well. Unlike the OE, the seal is "slotted", so I went to the hardware store and got an oring the right size to fit in there. That made it seal much better, and it's been fine since (~1 year).
GoPats is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 07:29 PM #5
Old4runnerguy Old4runnerguy is offline
Old4runnerguy is on a distinguished road
Gas cap?
Old4runnerguy is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 07:33 PM #6
Urbanite Urbanite is offline
Urbanite is on a distinguished road
When this happened to me, a new OEM gas cap resolved the problem. I love the "thump" my new gas cap makes when you remove it. This tells me it's pretty tight and what I'm hearing is pressure release from gas tank.
Urbanite is offline   Reply With QuoteReply With Quote
4th gen 4runner , check engine light , gas cap , traction control light , vsc off light
Check engine light, vsc light, traction light all on after a short circuit mikeng 4th Gen T4Rs 3 01-01-2018 07:54 PM
VSC Off, Check Engine light and the traction control squiggly thing again... Nuke 4th Gen T4Rs 22 05-30-2016 09:39 PM
New tires: Check engine/traction control lights on BPo001 4th Gen T4Rs 12 04-18-2013 11:06 AM
vsc, vsc off, traction control light, check engine lights Dunk50 General Discussions 1 10-26-2011 06:22 PM
'08 4Runner check engine/vsc/traction control lights Ant3_16 4th Gen T4Rs 2 03-11-2009 12:32 AM
