Alright I figured it out!
Credit to UNSNUB on tundra solutions . I came across the following statement from him "
The air fuel sensors have thier own fuse located in the same box you pulled off. It is a 15 amp fuse called AF Heater and also there is a relay called AF Heater Relay."
Then it hit me..... I was on a roadtrip and got the flashing AC light. I ended up swapping the mag clutch relay with......the af heater relay to get the AC working.
I swapped the relays and now the codes are gone. I'll update if they come back.
