Old 07-13-2016, 06:25 PM #1
helloericlieu helloericlieu is offline
helloericlieu is on a distinguished road
HELP! 06-09 LED Tail Lights don't work on my 2003
Long story short, after reading that the 06-09 4runner tail lights will fit on my 2003 without modification, I went on Ebay to buy a set of 06-09 tail lights.
I've made sure all the bulbs were in tight making good contact, all the plugs were securely snug, I've also read that plugging both sides in would make it work, but it didn't.
The blinkers don't blink, and the reverse do not come on, but the LED brake lights work.
I've also confirmed that my Bulbs work fine.
Any other things I can try??
helloericlieu is offline   Reply With QuoteReply With Quote
Old 07-13-2016, 06:37 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Maybe some ideas in this thread ...
OEM LED tail light Install w/ pics
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 07-14-2016, 02:38 AM #3
Thanks for the link, that's actually the same thread that I used to trouble shoot with, I've made absolutely sure that my bulbs were in tight making contact to the metal pieces. Issue still occurs..Sigh....I guess I'll try it again, hopefully with better luck.
Old 07-14-2016, 12:03 PM #4
NinjaOne's Avatar
NinjaOne NinjaOne is offline
NinjaOne will become famous soon enough
NinjaOne's Avatar
Fuse? Do your old ones work? Your front blinkers work?
They worked great on my '04, fitment was super tight but they work great. (Ordered the TYC brand, but doubt it makes a diff)
<a href=https://www.instagram.com/t4r_juan/ target=_blank>t4r_juan</a>
NinjaOne is offline   Reply With QuoteReply With Quote
Old 07-14-2016, 01:08 PM #5
Porqupine82's Avatar
Porqupine82 Porqupine82 is offline
Porqupine82 will become famous soon enough
I had the same issue, turned out the twist cap is ground.
Instagram: overland_tennessee
Website: www.redclayrally.com
Porqupine82 is offline   Reply With QuoteReply With Quote
Old 07-14-2016, 06:07 PM #6
My fuse is fine, as my original tail light/reverse/rear blinker/front blinkers work just fine. I ordered the Eagle Eyes brand off Ebay.
I'll have to try and twist it in super snug and see if I was just doing it wrong, there's these little arrows on the bulb holder that let you know if the metal is making contact.
Which twist cap are you referring to as ground? the twist cap to the blinker bulb, or to the reverse bulb?
Old 07-14-2016, 11:42 PM #7
If i recall, the one to the brake... you plug the wire into the LED module, then you have to stuff the wires inside and reapply the cap, like in the old taillight. You can't leave it off or the lights won't work you'll see the metal ring on the taillight housing
Old 12-16-2016, 04:19 PM #8
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
@helloericlieu did you ever figure out what was wrong with them? I receive mine yesterday and was putting them in today. No matter what I did I couldn't get the reverse light to work on the driver side. Yes, the fuse was fine and the bulb was fine. I put my old light back in and it worked fine......confused
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 12-16-2016, 06:26 PM #9
Nope, I ended up returning the taillights due the very same issue you've experienced plus my blinkers not working.
Old 12-16-2016, 06:55 PM #10
momo.75's Avatar
Registered User
Real Name: Morris
Registered User
momo.75's Avatar
Real Name: Morris
You order another set?
Old 10-13-2017, 10:53 AM #11
rodcagle rodcagle is offline
rodcagle is on a distinguished road
I installed mine last week. I tested this and if you do not plug the gray housing (looks like a bulb socket the plug goes into) and twist it in place, it will act just like this. You get LED brake lights, but no turn signal and reverse light. It is in the write-up listed above, but you can miss that step. That socket grounds the other 2 bulb connections.
rodcagle is offline   Reply With QuoteReply With Quote
FS; 2003 (4th gen) Limited running boards, headlights, and tail lights; $350 Kansas Midwest4Runner For Sale: T4R Items 15 12-28-2015 08:29 PM
FS: 2003-2005 OEM Tail Lights, $20.00 shipped for either L/R. $30.00 Shipped Both sluggercz For Sale: T4R Items 1 08-21-2013 12:18 PM
2003-05 Depo Euro Style Altezza Chrome Tail Lights (pair) crmartin9 For Sale: T4R Items 1 04-18-2013 12:54 AM
Will these tail lights work on my 06? knightsfs4 4th Gen T4Rs 2 06-06-2011 04:24 AM
2003 stock tail lights. racefan_67 Classifieds - buy & sell (no commercial ads please) 4 05-22-2008 07:28 AM
