Old 07-19-2016, 08:32 PM #1
dg0503 dg0503 is offline
dg0503 is on a distinguished road
Transfer case needs replacing
So my 2009 4Runner (4wd, V6) would not go into 4Lo. I took it into the dealer and as expected, the actuator needed to be replaced. I was not surprised and thankfully I purchased an extended, comprehensive warrenty when I bought the vehicle a few months ago. The dealer just called and said that the transfer case also needs to be replaced. There are metal shavings in the casing. The truck has less than 70000 miles on it. Anyone else have a similar situation or knows what may have caused this? Again, thankfully this will also be covered by the warrenty, but I am concerned about other issues coming up. Should I be?? Thanks.
dg0503 is offline   Reply With QuoteReply With Quote
Old 07-21-2016, 12:08 PM #2
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
oil starvation, failing to change the transfer case oil when water entered the case. That's about all I can think of with that low of mileage. It could also be a defective bearing/part inside the case that is in no way your fault.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 07-21-2016, 12:18 PM #3
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
When I first replaced the fluid in TC, I did see very small metal shavings, but didn't think much of it. Also, don't forget to use it (engage it) every month and for at least 10 miles, drive to keep things lubed up and working! Actuator failures are starting to become common as our rigs age (expected), so it doesn't surprise me when i see a member complain of a "new to them" 4Runner and run into TC problems.
1) change the fluid every 60K miles
2) Use it at least once a month (4hi, 4lo, lock the diffs)
3) Drive in 4hi at least 10 miles
Good luck with your new TC!
CookieRoe is offline   Reply With QuoteReply With Quote
Old 07-21-2016, 12:35 PM #4
Morphyne Morphyne is offline
Morphyne will become famous soon enough
Maybe if someone drove on dry pavement with lots of twists and turns with it engaged for an extended period of time?
Morphyne is offline   Reply With QuoteReply With Quote
Old 07-21-2016, 01:08 PM #5
Thanks for the replies!! Anything to be careful of with the new TC? About to head out on a road trip, pulling a pop up camper.
Old 07-21-2016, 01:44 PM #6
shouldn't need TC pulling a camper unless get into the muck real bad. if that, then give it hell.
Replacing Transfer Case Output Shaft Oil Seals, a How-To for DIY'ers BigFishAllDay 3rd gen T4Rs 82 06-21-2023 09:37 PM
WTB: 4th gen V6 transfer case shift motor/transfer case drewskie88 Want to Buy/Trade 0 01-11-2016 12:41 PM
Replacing Transfer case-any writeups? c0mmon 3rd gen T4Rs 13 09-16-2015 01:10 PM
What Mileage for Replacing Differential & Transfer Case Fluids? HBhawk Maintenance/Detailing 15 09-21-2010 10:23 PM
Advance Adapters 50-5705 Transfer Case Adapter 700R-4 To A Toyota Transfer Case 21 To NMRunner Classifieds - buy & sell (no commercial ads please) 0 08-18-2010 11:42 PM
