Old 07-21-2016, 10:22 AM #1
4Rnr4Evr's Avatar
4Rnr4Evr 4Rnr4Evr is offline
4Rnr4Evr is on a distinguished road
4Rnr4Evr's Avatar
ABS woes
Several months ago I had a front right wheel hub replaced by a reputable shop. About 500 miles later ABS light came on and VSC Off started flashing. Codes were 31 and 43, predictably - front right wheel sensor. Weirdly, the lights would go off occasionally after some driving on the highway but would show up when making a turn. When the lights were off, when braking in a turn the ABS would go crazy trying to kill me and then the lights would light up. At this point the lights are on 99% of the time and go off very rarely.
I replaced the corresponding sensor and nothing changed. I checked the harness with a multimeter and it rings OK. I'm now thinking that they messed up the bearing assembly and the tone ring got gradually damaged (because ABS worked fine for a few hundred miles after the install). Far too late to go back to the shop at this point but I can replace the hub assembly myself this time without breaking the bank. Except I don't want to throw parts at the vehicle without being certain they'll fix the problem.
EDIT: also, I tried cleraing the ABS codes and the lights light up within a few feet of driving after clearing them. Also tried zero point calibration and got the same result.
Any thoughts? Is there any possible way to test the abs ring in the hub?
no more T4R...
4Rnr4Evr is offline   Reply With QuoteReply With Quote
Old 07-21-2016, 11:04 AM #2
jfry008's Avatar
jfry008 jfry008 is offline
jfry008 is on a distinguished road
jfry008's Avatar
Did you remove the ABS wheel sensor cable from the car and apply tension to the cable while testing it?
Edit: or maybe swap left and right sensor cables and check codes
08' 4Runner SR5 4WD V6 Level 8 MK6 wheels//Kenwood DDX9903s//JL 10W3v3 on 500/1//LEDs//ICON Ext Coilovers FR//Metaltech LT Rear Springs w/ Dobinson LT Shocks//JBA UCAs//spidertrax//5th gen brakes in front//295/70/17 Cooper Maxx//SS brake lines//http://www.toyota-4runner.org/4th-ge...ld-thread.html
jfry008 is offline   Reply With QuoteReply With Quote
Old 07-21-2016, 06:44 PM #3
Oneluv13T4R's Avatar
Oneluv13T4R Oneluv13T4R is offline
Real Name: Miah
Oneluv13T4R will become famous soon enough
Real Name: Miah
Exactly, what I was thinking since this is what solved my abs crisis like the op is having.
4th Gen 2WD to 4WD CONVERSION
2003 SR5 T4R Pac Blue Metallic w/rear locker, on 35" Mastercraft MXTís, TC uca"s, TC lca"s, 2.5 King C/O's w/remote resi TC lca gusset kit, Taco Tabs, 2.5 Icon remote resi w/adj on rear Shock Hoops, adj panhqrd A 3.5" lift springs, 10" HD Series AirLift bag, hidden winch W/ 10k Smittybuilt, DMZ eng mounts
Oneluv13T4R is offline   Reply With QuoteReply With Quote
Old 07-22-2016, 10:31 AM #4
4Rnr4Evr's Avatar
4Rnr4Evr's Avatar
Definitely not the worst idea I've ever heard, I'll try it tomorrow.
no more T4R...
Old 07-23-2016, 11:56 AM #5
4Rnr4Evr's Avatar
4Rnr4Evr's Avatar
Swapped the cables, cleared the codes, drove 200 ft, codes popped back, same as before. So I'm still thinking it's the tone ring.
no more T4R...
Old 08-02-2016, 07:01 PM #6
4Rnr4Evr's Avatar
4Rnr4Evr's Avatar
Unfortunately I was correct. As I came home tonight I felt like messing with it, so I took the wheel off, removed the sensor and tried to look in the hole with a focused flashlight... well I could easily see the ring is separated from the bearing and just rattles around. Not sure you can see it on the photo but it's pretty hard to take a good picture through that tiny hole.
So now I am likely looking at getting a new hub assembly, I doubt this can be repaired? I'll call the shop tomorrow but it's been at least 10K miles since they did the work so I doubt they would be willing to do anything about it.
ABS woes-abs_ring-jpg
no more T4R...
Old 08-04-2016, 11:35 AM #7
sonerick's Avatar
sonerick sonerick is offline
Real Name: Nick
sonerick is on a distinguished road
sonerick's Avatar
Real Name: Nick
I had this issue at one point too due to a defective hub/bearing assembly. I had installed it myself, and had followed the proper procedure, didn't notice anything unusual, etc. during install. New hub/bearing assembly cleared it right up though. Also gave me an opportunity to replace the inner hub seal, which I hadn't done the first time around.
You can get the hub/bearing pre-assembled from one of the guys on the forum, I'd recommend going that route if you plan to DIY. Good luck.
2017 Chevrolet Silverado 1500 LT Z71
2011 Audi A4 2.0T Quattro
2005 4Runner SE V6 4WD (Sold)
2004 Volvo S60R (Sold)
1999 Jeep Cherokee Sport (Sold)
sonerick is offline   Reply With QuoteReply With Quote
Old 08-04-2016, 11:58 AM #8
4Rnr4Evr's Avatar
4Rnr4Evr's Avatar
Yeah I've already contacted him. I think that's the safest and quickest fix.
no more T4R...
4 lo woes Rico 5th gen T4Rs 8 06-16-2015 10:33 PM
T4R woes Mojo29 3rd gen T4Rs 8 07-21-2010 04:06 PM
More MAF woes... SammerP 3rd gen T4Rs 5 05-15-2010 09:12 AM
Best Buy Woes Slider Off Topic 18 10-04-2007 09:04 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
