07-28-2016, 09:02 PM
Back window won't roll all the way down..
Hi guys,
when I hold down the button on the FOB key to lower the rear window, it only cracks it open a few inches..
if I use the switch inside above the 4WD switch it rolls up and down no problem..
is there some sort of setting Im missing here?
thanks..
07-28-2016, 10:52 PM
I let go of the button once it starts moving and it automatically lowers the rest of the way...
07-28-2016, 11:16 PM
From the Owner's Manual ... Opening Back Window
"To open the back window, push the back window open switch of the transmitter for about 1 second. The window will fully open."
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
07-28-2016, 11:46 PM
Tried it several ways. Press and hold. Just press. I get the beep and then it cracks the window down a few inches. Not down completely. It's weird.
2007 Toyota 4runner Sport Edition 4x4, 15% tint, 1.5 inch ALL PRO spacers, de badged, Full interior LED swap (cluster, hvac, etc), plastidip wheels, blacked out headlight housing, K&N, smoker kit, carbon fiber shifter knob, carbon fiber interior wrap, diff breather mod, added VSC off mod, added Compass rearview mirror, independent fog lights, DTRL delete, zXe bulbs, Jensen VX7022 NAV head unit, back up camera, custom rear storage
07-29-2016, 08:09 AM
07-29-2016, 09:26 AM
Real Name: Neil
Real Name: Neil
Your key fob could be failing or needs a new battery.
1st was an 87, 2nd was a 95 and 4th gen is a 04 V8 Sport. OME 885/Toytec RCC2.0HD, SPC UCA's, RCI Sliders with top tread, Airlift 1000, and BFG ATKO2's - 265/70/17's. Tekonsha brake controller, EBay interior LED's, and Kenwood DDX 594 radio. Yakima roof rack for all seasons up top.
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
07-29-2016, 10:39 AM
Any chance you
have the window safety switch (on the arm rest) enabled?
07-29-2016, 02:58 PM
Ok. Tried to do the reset.
When I use the switch inside. It only cracks it open, if I hold the down button. And if I hit the down button again it will roll all the way down. I checked the track. There isn't anything in the way.
So basically whether I use the key fob (have 2) or the inside down button it only cracks open. If I hit the key down again it does nothing but beep. If I hit the inside down button again it will roll down.
Any thoughts?
07-29-2016, 06:47 PM
Is the rear wiper in the neutral position?
http://www.toyota-4runner.org/proble...look-here.html
I'd try the re-initialize procedure again, and be sure that there are no safety window locks on anywhere.
