Originally Posted by kylixz
I've had a nearly bone stock 2004 V6 limited for the last 6 years and absolutely love it.... and have lurked here for awhile admiring everyone's builds! Now has 150k miles of adventure around the country on it!
In any event... I'm looking to tow a 2500lb dry trailer around the US for nearly a year with some light offroading needed when I drop my rolling home places. I'm thinking my 04 V6 with the 4 speed isn't going to like dragging even a small travel trailer fulltime even if I get some fresh suspension, airbags, and a transmission cooler.
I've found and 06 V8 with a Toytec lift that looks clean with 100k miles and seems to run great at around $20k. Any thoughts? Should I just give it a shot with the V6? I already have a WDH. Trailer has brakes. Or should I go for the slick looking newer model with more torque to drag 2500lbs around?
Thanks,
Steve
as they have said above, the v6 will pull that weight.
however, and this is just a guess, the v8 will pull that weight, while getting slightly better mileage. as it wont be working nearly as hard. I expect the v6 would be in the low double digits, maybe even single digits if there are a lot of hills...
so, if you are talking long term, it will use less fuel. it may not matter, and you will likely never recover the cost of the vehicle in fuel savings. but it may mean a few less fuel stops.
also, $20k is too much for that rig..
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
