Old 09-06-2016, 01:07 PM #1
4by4runr's Avatar
4by4runr 4by4runr is offline
4by4runr is on a distinguished road
4by4runr's Avatar
Radiator replacement - when?
What mileage or age do you guys typically replace the radiator on the v8? I have no leaks that I'm aware of.
2004 V8 4x4 sport in Galactic Grey • Xreas delete • 248k • BFG KO2 265/70/17 • Custom Arizona sun two tone paint • 2" leveling kit
4by4runr is offline   Reply With QuoteReply With Quote
Old 09-06-2016, 02:05 PM #2
KBToys KBToys is offline
KBToys is on a distinguished road
I'm just ordered a new radiator due to a leak. I'm at 95k in miles
Sent from my SM-N910V using Tapatalk
KBToys is offline   Reply With QuoteReply With Quote
Old 09-06-2016, 02:07 PM #3
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
I had a slow leak around 100000 miles on a v6. I guess replacing it every 100000 miles would be a good maintenance.
radlynx is offline   Reply With QuoteReply With Quote
Old 09-06-2016, 02:09 PM #4
MrRoo's Avatar
MrRoo MrRoo is offline
MrRoo is on a distinguished road
MrRoo's Avatar
If it aint broke don't fix it. Really. If you have lots of corrosion then that's another story. But if you've changed your coolant on a regular schedule you should have no issues unless you spring a leak. There is no schedule for radiator replacement. Now a 3rd gen is a different story. 100,000 on a 3rd gen or 10 years about is all they last before pink milkshake brings all the girls to the yard.
97 SR5 loaded. (sold)
98 SR5. (Sold)
2004 V8 Limited Current DD
2010 Highlander Limited wife driver and kid hauler
MrRoo is offline   Reply With QuoteReply With Quote
Old 09-06-2016, 02:22 PM #5
jreask's Avatar
jreask jreask is offline
jreask is on a distinguished road
jreask's Avatar
The radiators tend to leak up high and with small leaks that are hard to detect. Usually upper driver side. You can't see it but the overflow is empty, the radiator stops leaking when it hits the level about an inch below the top. Not enough to overheat but it will start leaking when you fill it up above the level of the leak.
jreask is offline   Reply With QuoteReply With Quote
Old 09-06-2016, 02:31 PM #6
CXS CXS is offline
Real Name: Chris
CXS will become famous soon enough
CXS CXS is offline
Real Name: Chris
I'm at 205k with original radiator, I'm also of the "If it aint broke don't fix it" belief.
Chris - '07 SR5
‘05 Limited - sold
CXS is offline   Reply With QuoteReply With Quote
Old 09-06-2016, 03:29 PM #7
4by4runr's Avatar
4by4runr's Avatar
Coolant had been changed once at 92k for timing but no water pump. I'm getting ready to have the timing belt done. Would it be cheaper and to have them just do the timing belt idler pulleys and maybe seals and the do the water pump, radiator and thermostat myself? And or can the water pump be done easily?
Old 09-06-2016, 04:21 PM #8
CXS CXS is offline
Real Name: Chris
CXS CXS is offline
Real Name: Chris
My mechanic did what he referred to as the "timing belt kit" which included all the related pulleys, belts and water pump. Last time I told them to not replace the water pump but at 200k but I decided to go with a new one this time.
I'm not clear on why you want to replace the radiator, it may be fine and just doing a complete flush should be fine.
Chris - '07 SR5
‘05 Limited - sold
Old 09-06-2016, 04:53 PM #9
4by4runr's Avatar
4by4runr's Avatar
I guess I don't. Just trying to save some money if I can do the external stuff myself. I have been shopping around and getting quotes for $1000-1500 which is about $450 on the belt, $300 on the wp, $150 on the tstat and then seals and pulleys on top. I can handle the tstat and pump if it doesn't involve tearing into anything else, I know where my skill set ends ��. The radiator came up during conversations with shops, I wasn't really sure if it needed it. I could see the pulleys and seals being a better choice of spending. Currently at 175k - thanks all
Old 09-06-2016, 05:12 PM #10
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
I'm curious about this. Where have you seen them leak? I understand it can be difficult as you say, but it has to leave evidence somewhere? I ask because I had some unexplained loss of coolant in my overflow, but no evidence of any leak... other than some crustiness at the overflow cap. some reading led me to believe that I might have topped off my overflow too much and through expansion, overflowed from the reservoir cap. I started to suspect a HG issue since I have a V6 (but an '08, where the VAST majority of HG issues were in the earlier 4th gens, specifically the '04's). No evidence of leaks that I could find anywhere else. I've since done my 150k flush and no loss of overflow. So I'm curious when I hear of issues pertaining to current goings on with my vehicle. Not trying to call you out or anything, just want to hear more if you have any more..
OP, count me among the "leave it alone if it's ok" crowd... If you keep to your flushes, then you ought to be fine.
2008 SR5 4WD
bob3dsf is offline   Reply With QuoteReply With Quote
Old 09-06-2016, 06:39 PM #11
97hb's Avatar
97hb 97hb is offline
97hb is on a distinguished road
97hb's Avatar
Dont have a V8 but my original V6 radiator is going strong at 387,000+ miles. No leaks, no scale, no rust, but I dump and refill more than most and have a coolant filter. Original water pump also. Keep your coolant fresh is my motto, probably why my original headgaskets have not popped yet haha!
2017 Ram 3500 4X4 - The hauler.
2003 SR5 4X4 4Runner - 412K+ Off-road Toy.
1997 Civic SFWD 674hp 530tq - Because racecar.
97hb is offline   Reply With QuoteReply With Quote
Old 09-06-2016, 08:27 PM #12
4by4runr's Avatar
4by4runr's Avatar
So is the concensus then to do the timing belt, pulleys, seals and thermostat and wait for the the rest to start leaking or give me a reason.
Old 09-07-2016, 01:57 PM #13
jreask's Avatar
jreask's Avatar
The ones that I have had leak the leak was so small that the liquid would evaporate before reaching the ground. It would run down and start to cross the radiator support. Like I said the leaks were almost undetected until the radiator was removed. Enough to lower the level in the radiator. After it reaches this level it never leaks again but it's not low enough to overheat. Hope this helps.
Old 09-07-2016, 02:05 PM #14
4by4runr's Avatar
4by4runr's Avatar
Just checked my coolant ph, it's sitting right about 7.0 (ph neutral). Still looking for an affordable shop in Tucson for the timing group.
Old 09-07-2016, 02:06 PM #15
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
Man, you just jinxed yourself.
I plan on replacing mine when it starts leaking. Currently at 157k, no leaks yet (crosses fingers).
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
03 radiator replacement kirkg 4th Gen T4Rs 17 10-20-2014 07:55 PM
Replacement radiator dirtrider9x 3rd gen T4Rs 9 02-22-2013 08:19 AM
Radiator replacement sonjason 3rd gen T4Rs 11 02-23-2011 01:10 PM
Radiator Replacement how-to doggernaut 3rd gen T4Rs 5 04-11-2009 06:45 PM
