Originally Posted by JustinCG
Thanks for sharing. I have been dealing with this same type of issue for a few months now. I took it into a shop and they had to replace the waterpump seal. the pump was replaced 20k ago and the mechanic said that the person who put in my pump didn't replace the seal...but the same type of leak is back again just how you described it. I open my radiator cap and its full. but my reservoir coolant always goes down to the bottom. I have coolant marks on the top of the reservoir. do you think its the radiator?
Mine was actually doing something a bit different than I thought it was. I believe I updated this thread, but I might not've.
After long drives it would push tons of coolant into and out of the reservoir but then wouldn't suck it back in once it cooled down. And there would be lots of pressure under my rad cap even when the overflow was full. But even then, there would be a lot of air in the radiator instead of coolant.
That said, the radiator is definitely worth looking at. The leak in mine was actually on the back, so the shop I'd gone to hadn't been able to find it.
'04 4Runner -
Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
