09-21-2016, 06:48 PM
Class C vs Class E Tires
Hi guys,
I'm in a bit of a dilemma. I want to run 275/70/17 KO2 tires but I see this size is only available in class E. The smaller 265/70/17 is available in both class C and class E.
Is there really that noticeable difference in ride quality between the two classes of tires? I've heard some complaints about the E and some say it's not that big of a deal.
What do you think?
2006 4-Runner XSP V6
SCS Ray10 17x8.5 (Matte Black)
Falken ATW3 Wildpeak 265/70/17
Daystar 2.5/1.5
09-21-2016, 06:54 PM
Real Name: John
Real Name: John
Originally Posted by luke87gt
Hi guys,
What do you think?
I have that exact tire on my 3rd gen. 275 70 17 E rated. Great tire. I notice no difference. Just dont run them at 60psi. I run mine at 40psi.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
09-21-2016, 06:59 PM
Hi guys,
What do you think?
if you run the correct pressure, I doubt you would notice much difference over a C rated tire.
however, you may notice a difference over the OEM P rated tires, if that's what you will be replacing.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
09-21-2016, 07:01 PM
I'd always go with E-rated tires if you ever drive on gravel roads or off pavement...a bit more stiff but that can also be used to aide in on-road manners...Stiff side-walls warrant a slightly stiff ride compared to mushy Cs...but I doubt you'd notice...I hate flat tires and drive hundreds of miles on gravel roads and quarry-spawl roads...with Cs, you'll find yourself on your knees (more)...haha, it rhymes...than again, so does Es...
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
09-21-2016, 07:49 PM
Real Name: Emory
Real Name: Emory
I'll mirror what others are saying ... I have 275/70/17 KO2's on my '06 and, as long as the pressure is right for the load and situation, you'll feel little difference. Under normal circumstances I run mine at 45 psi
2006 4Runner Sport Edition V6 4WD - Shadow Mica
2005 4Runner SR5 V6 - Titanium Metallic
2004 Sequoia SR5 V8 4WD - Natural White w/ Silver Sky Metallic cladding
2002 4Runner SR5 Sport V6 4WD - Black
Yes, I still own all four ...
09-21-2016, 08:43 PM
Real Name: Chris
Real Name: Chris
+1, i run 275/70/17 KO2s on my truck (honestly a pavement going DD) and i am very happy with them.
2006 V8 Limited - Icon/Bilstein/Daystar - Yakima - SCS F5 / BFG KO2 275/70/17
2007 Corvette Z06 - WCCH Heads / BTR Cam / M2W / Corsa CF intake / Forgestar F14
Real Name: Sean
Real Name: Sean
I had the same debate and went with the 265/70/17 C. Got to ride on some Es and they did ride harder, but that wasn't the reason I didn't get them. My bigger concern was the weight. I like my truck to be quick. Also, most of my off-roading is sand and mud. The softer side walls actually help.
I really wanted the bigger 275 so I was torn. Now that the 265s are installed, they look great and I have no regrets.
2008 Limited V8 4WD | T4R TRD Pro Suspension w/ Toytec Spacer and Superflex Rear Coils | 275/70/18 Duratracs | RCI Sliders & Alum. Skids | Gibson SS Exhaust | WMW Rack
2005 Limited V8 4WD | FJ Coils w/ FJ TRD Shocks & Struts | 265/70/17 BFG KO2 | Toytec Spacer Lift | Borla Exhaust | WMW Rack w/ Ladder | 06-09 Headlights w/ HID | Scion Nav - SOLD
09-21-2016, 09:29 PM
I got the 275/70/17 KO2 (E) about 6 months ago. They are nice and quiet. Nice on Hwy.
Mileage took a hit. Maybe lost 2 or 3 mpg.
I've used them on the rocks and sand
Aired down to 15 all week on OBX beach vacation, did great.
Tested out the ATRAC on some rocks recently at about 20psi.
Good bit of spin before ATRAC took over, tires did great, not a mark on them.
I had seen some concern online about rain handling. Its been raining solid here in VA Beach for 3 days. Lots of standing water and have no issues at Hwy speeds.
100% recommend.
_________________________________________________
2008 SR5 V6 4WD Toytec 3" lift, BFG 275/70-17 KO2, JBA UCA, 4xInnovations WeldOn Sliders
1985 FJ60 OME-4Plus lift Micky Thompson 33's, Aussie Locker, Mucho Rusto
09-21-2016, 10:05 PM
The e rated tire will be significantly heavier If I remember right the c rated will be 6 ply and the e rated will be 8 ply
Sent from my SM-G900W8 using Tapatalk
09-22-2016, 07:27 AM
An E rated tire is way overkill for our 4runners, drastically heavier so yes you will notice fuel mileage loss and you are not really gaining anything by using them. They are not better off road because they don't flex and you are not putting 2,000 lbs inside your vehicle, E-rated tires are for work trucks 3/4 or 1-ton+ unless you are plowing with your 4runner (alot) or driving around construction sites or junkyards where you are worried about a puncture there is no reason to use E's
09-22-2016, 07:29 AM
Went from C to E KO2s. The Es are unbelievably smooth. Don't believe he hype about a rough ride. If you're concerned about a 2mpg loss - you're driving the wrong car.
I keep mine at 38# and they're smooth as butter at 85.
2007 V8 Sport Edition: Definitely Not Stock
2014 LX 570: Stock
09-22-2016, 08:50 AM
Real Name: brian
Real Name: brian
I had "e's" on my oem 18" and they were fine. lost mileage but that's it. eventually went to 20"s so got rid of them.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
10-21-2021, 10:47 PM
Stock size KO 2 (E Load Rating)
I have a 5th Gen TRD Pro in need of new tires. Im leaning towards the Ko2 in E load rating. Interested in any feedback from people who are running stock size KO2s in E load as to what pressure they are running as well as any other feedback (Positive or negative). I’ve read through most of the threads with mixed responses. Looking for some new responses.
Thanks
