Old 09-27-2016, 08:42 PM #1
delucat2 delucat2 is offline
delucat2 is on a distinguished road
All fuses good - no trailer running lights
This no running lights for trailer is driving me nuts. I knew that I had a short in my trailer running lights when I got home after a trip (a clearance light got crushed) and noticed the running lights were out. No LED on the 7 to 4 pin converter that plugs into the stock lighting 7 pin socket. That did not surprise me, figured I'm looking for a blown fuse. Checked all the fuses in the fuse block under the hood - 1) Towing Brk 30A, 2) Towing 40A, 3) Towing 30A as is the Tail 10A in the little panel above the emergency brake. Not the fuse? I ordered a replacement "converter" the one buried in the panel above the rear tire fender behind the trim. Replaced it....nothing. No running lights.
I can always run a jumper from the wires one of the rear running lights to the harness just before the 7 pin connector, but I would like to actually find and fix the problem.
The posts I have seen talk about the converter and the fuses, but those are all new, so where do I start looking at this point?
2003 w/ factory tow light package
thanks
tony
delucat2 is offline   Reply With QuoteReply With Quote
Old 09-27-2016, 09:05 PM #2
CXS CXS is offline
Real Name: Chris
CXS will become famous soon enough
CXS CXS is offline
Real Name: Chris
I found a broken wire in mine when I had that problem. I have the tow package so didn't expect the problem to be in the loom but it was. Unfortunately you may have the same issue that requires digging into the loom wires and checking each wire.
More probable is the crushed light assuming the lights worked until getting damaged.
Chris - '07 SR5
‘05 Limited - sold
CXS is offline   Reply With QuoteReply With Quote
Old 09-28-2016, 10:46 AM #3
DisguisedRope's Avatar
DisguisedRope DisguisedRope is offline
DisguisedRope is on a distinguished road
Have you checked for voltage on each pin the seven pin connector without your adapter in? Its always possible that the adapter went bad or is not making a good connection.
2008 4Runner SR5 4.0 V6 4x4
Toytec Boss Suspension System with 2.5 Series Performance Coilovers; Skyjacker Extended Rear Sway Bar Endlinks; Ebay Uniball UCAs; Cooper Discoverer AT3s LT265/70/17; URD MAF Cal; URD Stainless 3" Mark3 Exhaust; aFe Stage-2 Pro DRY S Cold Air Intake; Black Headlight Mod; 5000K HID in Low Beams; 3000K HID in Fogs; 9011 HIR in High Beams; Weathertech in channel visors; 20% tint on front and over factory tint; 5% eyebrow on windshield; Plastidipped grill, badges, rear bar, wheels, etc.
DisguisedRope is offline   Reply With QuoteReply With Quote
Trailer running lights/fuse question mc813 5th gen T4Rs 12 11-08-2020 02:56 PM
No Trailer Running Lights (have brakes and flashers) MtAiryEd General Discussions 13 04-29-2018 07:25 AM
Trailer running lights not working abw73 3rd gen T4Rs 1 09-24-2015 04:26 PM
Trailer Running Lights golfinw71 4th Gen T4Rs 5 06-03-2014 08:39 AM
I keep blowing fuses for fog lights DC2LA 3rd gen T4Rs 4 03-21-2006 01:39 AM
