Originally Posted by Brian3676
They likley gave you the correct bolt. There is not supposed to be a bolt/nut there. Its jusy a bolt and the spindle is threaded.
I assume at some point it was drilled out and the person used a nut/bolt. You could helicoil it and make it like OEM, or cut the bolt off and head to the hardware store and find a new nut/bolt.
That's not the correct bolt, that actually looks like a cylinder head bolt, though it appears a bit short (Toyota doesn't really use a 12-point head on their bolts for much else really).
It should be something like a M12 or M14 both with a 17mm head if I remember right, I don't recall the thread pitch or bolt length off the top of my head though.
