Old 11-01-2016, 07:08 PM #1
rrflyer rrflyer is offline
rrflyer is on a distinguished road
Headlight housing
Anyone have suggestions on replacement headlight housing for an 06 sport?
Factory are around 450$
rrflyer is offline   Reply With QuoteReply With Quote
Old 11-01-2016, 07:23 PM #2
AKmoney AKmoney is offline
AKmoney is on a distinguished road
Are they turning yellow/cloudy? If that's the case you can restore the plastic by a wet sanding/polishing + clear coat process for way less than the cost of a new headlight. No need to replace the original housings.
AKmoney is offline   Reply With QuoteReply With Quote
Old 11-01-2016, 08:01 PM #3
Ines cracked and crazed almost black on top, the other is full of water
Old 11-01-2016, 08:04 PM #4
If that's the case you've got three options:
1) Buy factory. This will be the highest quality.
2) Buy cheap aftermarket replacements from eBay/Amazon for $150. Quality is much lower.
3) Look on Craigslist for something used. You might get lucky.
Old 11-01-2016, 08:35 PM #5
hullinger hullinger is offline
hullinger is on a distinguished road
Since you'll be replacing those lamps, this might be a good chance to do a little experiment with your old units. You could use different methods to clean the lens then leave them out in the sun for the winter to see which method works best.
As an example, I've seen Youtube video of folks using bug repellant as a cleaner, and it works, however only short term.
Chris
hullinger is offline   Reply With QuoteReply With Quote
Old 11-01-2016, 10:48 PM #6
Stuffman's Avatar
Stuffman Stuffman is offline
Stuffman is on a distinguished road
Stuffman's Avatar
I took mine out...Let dry... super glue the crack lines...put it back in... no water gets in when it rains but it looks like crap. I heard clear nail polish also works. Will get you some photos in the morning.
2005 T4R Silver, Limited, V8, Nav, Bil 5100, 1.5" front lift, Man-fre skid, Secondary Air Pump bypass
Stuffman is offline   Reply With QuoteReply With Quote
Old 11-01-2016, 11:20 PM #7
masphx's Avatar
masphx masphx is offline
Real Name: Mason
masphx is on a distinguished road
masphx's Avatar
Real Name: Mason
Has anyone used these or know of a better quality version? These dont get the best reviews I like how the housing is black.
https://www.amazon.com/Depo-312-1165.../dp/B005XRR4KY
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
masphx is offline   Reply With QuoteReply With Quote
Old 11-02-2016, 11:25 AM #8
The Yin's Avatar
The Yin The Yin is offline
The Yin is on a distinguished road
The Yin's Avatar
I got the tail lights from Depo. I've been happy with them, but I did add some extra sealant to make sure they would not leak.
I got my head lights from CarID, the Spyder model. I also added extra sealant to these and they have no leaks or cracks. However, I do have 2 concerns. First, the bulbs did not fit as snug as on the OEM housings. Not sure if that is a design flaw on all of them or just mine. I just cut an o-ring and used that to tighten up the fit. Second, after over a year of use, there is some kind of coating that is chipping off the glass. It looks fine otherwise, and I've bought some head light restore stuff to use on it, if I ever get around to trying it.
-The Yin
2005 T4R Sport V6 2wd
The Yin is offline   Reply With QuoteReply With Quote
Old 11-02-2016, 05:23 PM #9
gshadow325 gshadow325 is offline
gshadow325 will become famous soon enough
go to retrofit source and buy some buytl sealant
https://www.theretrofitsource.com/mo...lue-51566.html
youtube how to open your head lights.
stick some of that sealant into the groove all the way around the head lamp. use some clamps and close it back up. look up my head lamp retrofit for an idea what i'm talking about. thats all it takes
gshadow325 is offline   Reply With QuoteReply With Quote
Old 11-02-2016, 06:50 PM #10
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
I dry one of mine out after every time I go to an automatic carwash. It's in good condition, but I guess the seal leaks a little. Not worth re-sealing in my opinion, but I think there is a DIY for that somewhere.
To dry it out, I just pull out a couple of the amber bulbs (turn signal, DRL, parking. Why are there so many?) and let it sit in the sun on a dry day. If that's not enough, put a small computer fan under the hood pointing into the housing while a couple bulbs are out.
2007 V8 Limited 4WD
m85476585 is offline   Reply With QuoteReply With Quote
Old 11-03-2016, 12:04 PM #11
CPT2nr88 CPT2nr88 is offline
CPT2nr88 is on a distinguished road
Rock auto has way better prices for headlights. I think its around 40$ for 03-05 and 80$ for the 06-09 projectors. When I retrofitted to the newer style that's where I got mine from. Tailights too.
CPT2nr88 is offline   Reply With QuoteReply With Quote
WTB: 06-09 Front Headlight housing calikev For Sale: T4R Items 0 04-10-2012 10:01 PM
Anyone seen/done a projector headlight housing on '10 TE ScottsdaleT4R 5th gen T4Rs 9 04-12-2011 08:02 PM
Headlight Housing 05T4RV8 4th Gen T4Rs 6 11-20-2010 03:31 PM
WTB: 06+ OEM headlight housing HB 4X4 Want to Buy/Trade 3 01-19-2010 01:41 PM
WTB: 06-07 headlight housing lawwailok Want to Buy/Trade 1 08-31-2007 06:15 PM
