Originally Posted by ddnww
I think what you are wanting is an airbag setup in combination with the bilstein 5100's. Im sure they don't make a bolt on system for the 4runner, so you would need a fabricated setup/brackets to mount the bags. Plus the compressor, tank, valves wiring etc. You will need to do a bit of research or go to a custom 4x4 , airbag, or hydraulic shop. If this in fact what you are looking for.
Yeah, this is what I was looking for. It does not appear that there is anything close to a finished system that is sold as aftermarket. As you said, the closest that there appears to be is an amalgamation of parts that may/may not work.
Now, the reason? Initially, I was concerned about two things: MPG and garage door height. I was concerned that after adding the lift and roof rack, I would be too tall to get in the garage. After some measuring, I think I'll be fine there. I wanted a suspension system that would allow my to lower the ride height when going into the garage and then lift when I'm back out on the trails. Now, it's more of a curiosity to see about saving some MPG's. Hearing that this might need to go to a custom 4x4 shop, I think I can afford to pay the extra gas.
I appreciate all of your feedback, guys!
