Old 11-05-2016, 11:10 AM #1
tychill tychill is offline
tychill is on a distinguished road
Suspension Lift Suggestions
Hello everyone,
The stock suspension on my 2005 T4R SR5 is in bad shape and needs to be replaced. Rather than replacing it with another OEM stock setup, I'm interested in going with an aftermarket solution and possibly a small lift. I've read most of the FAQs on suspension mods but I need some recommendations based on my needs.
I use my 4runner mostly for relatively short work commutes as well as backpacking/hiking trips on the weekends. I don't do any kind of recreational offroading but I have been in situations when driving to trailheads where the 4runner doesn't have enough ground clearance to get there. And since my suspension sags it frequently bottoms out on rougher trails.
I have no other modifications other than cosmetic but at some point I'll probably add some aftermarket sliders and skid plates. Bumpers and wenches are most likely a little overkill for my needs so this new suspension would only need to accommodate the extra weight of the sliders and skid plates.
Overall I'd like to find a nice middle ground between a rock climber and a commuter to allow me to push through the occasional rough trail when adventuring out on the weekends. Budget isn't too much of a concern for me.
Thanks for your help!
tychill is offline   Reply With QuoteReply With Quote
Old 11-05-2016, 11:19 AM #2
sportsbriefcase's Avatar
sportsbriefcase sportsbriefcase is offline
Real Name: J.R.
sportsbriefcase is on a distinguished road
Real Name: J.R.
Sounds like Bilstein 5100s all the around ought to take care of it. Complete set on Amazon is under $400.
J.R. (Sportsbriefcase)
Bozeman, MT
2007 SR5 4x4 V6 | Bilstein 5100s (1.75") | Spidertrax | Trail Edition Rims | 265/70/17 Dueler | Satoshi Grille Mod | HCF Delete | Running Boards Removed
**Sportsbriefcase's Build Thread**
sportsbriefcase is offline   Reply With QuoteReply With Quote
Old 11-05-2016, 11:26 AM #3
Would you suggest aftermarket coils to go with them?
Old 11-05-2016, 11:31 AM #4
Real Name: J.R.
Real Name: J.R.
I've seen where a lot of people use the FJ springs. This post is helpful:
4th Gen Suspension Options/FAQ
Bozeman, MT
Old 11-05-2016, 01:52 PM #5
drbiii's Avatar
drbiii drbiii is offline
drbiii is on a distinguished road
drbiii's Avatar
I have the FJ/bilstein 5100 setup and it's a very mild lift (.5" rear, 2" front). I have the 5100s set to 1.75" with the FJ springs.
It rides nicer than stock XREAS. Absorbs bumps better, but has a little bit more body roll due to the additional height.
It's a great setup if you spend most of your time on the road.
2007 SE V8 4WD
Black
20" Liquid Metal wheels w/ Michelin 275/55/20
drbiii is offline   Reply With QuoteReply With Quote
Old 11-05-2016, 03:02 PM #6
sport2004's Avatar
sport2004 sport2004 is offline
Real Name: James
sport2004 is on a distinguished road
sport2004's Avatar
Real Name: James
Would love to see a before and after profile to compare the rake.
I have a stock Sport right now and it has a fairly pronounced rake, X-REAS still intact. I don't know if the original owner did anything else with it, but have to say I like the profile right now. I'll post a pic when can. Since the rear is so high, a trailer probably wouldn't over-level it toward the back. But, I would like to swap out all the key parts, keep the profile with a little lift...
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
sport2004 is offline   Reply With QuoteReply With Quote
Old 11-05-2016, 04:03 PM #7
JeratBP's Avatar
JeratBP JeratBP is offline
JeratBP is on a distinguished road
JeratBP's Avatar
This is one of the lifts I'm considering, but I'm not finding the used FJ springs. Do you know which are the better options for new FJ springs - Moog or something else?
~ Jeremy
Blue J Overland (IG: @BlueJOverland)
'05 4Runner Sport V8
My Build
YouTube Channel - https://www.youtube.com/channel/UCc1...TX4cSgQwtH_hw?
JeratBP is offline   Reply With QuoteReply With Quote
Old 11-05-2016, 05:14 PM #8
drbiii's Avatar
drbiii's Avatar
I don't have any food before pics, but here are a few after.
2007 SE V8 4WD
Black
Old 11-05-2016, 10:28 PM #9
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
That's a looker, for sure...looks level.
*Edit to ask where the tubular style running boards can be sourced.
Regards, sport2004
Old 11-06-2016, 04:24 PM #10
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
3" difference. So I guess the sequence is select tires, then work around those for modification of rake and lift...(?)
(Image enhanced to show the top edges of the tires better.)
Regards, sport2004
Old 11-06-2016, 04:56 PM #11
S p a r k y's Avatar
S p a r k y S p a r k y is offline
Real Name: Mark
S p a r k y will become famous soon enough
Real Name: Mark
Craigslist usually best place, find a 2006+ sport or urban runner. Only ones with those tubes.
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
S p a r k y is offline   Reply With QuoteReply With Quote
Old 11-06-2016, 05:57 PM #12
sport2004's Avatar
Real Name: James
sport2004's Avatar
Real Name: James
Thanks...
Regards, sport2004
lift 4runner generation , suspension
3rd gen suspension suggestions? Tanyav14 3rd gen T4Rs 21 07-25-2022 05:42 PM
Suspension,lift inputs,suggestions??? SavinWillyWonka 4th Gen T4Rs 36 11-22-2014 04:02 PM
Suspension suggestions kpd1999 5th gen T4Rs 12 06-10-2014 09:21 PM
lift / suspension suggestions? need help deedst4r 4th Gen T4Rs 1 08-31-2011 05:55 AM
4th Gen: Need suggestions on suspension for a 04 Kenney Engines / Suspension / Wheels / Tires / Audio / Accessories 16 01-26-2011 02:22 AM
