Old 01-16-2019, 03:47 PM #1
overlandout's Avatar
overlandout overlandout is offline
overlandout is on a distinguished road
Middle Seat Removal
I searched but didn't find my answer.
I have a 2007 v8 SR5.
I have the 40/60 bench. I need to remove the 60% portion, but leave the 40%.
Anyone know if its possible or do you need both in place for one of them to work or is it possible to remove just one?
I already have the seat bottom removed, just wanting to remove the larger seat back at this point.
overlandout is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 05:13 PM #2
volkinator volkinator is offline
Real Name: Eric
volkinator will become famous soon enough
Real Name: Eric
Haven't seen anything for the 4th gen, I did this with my 3rd... Gained a lot of storage space with a platform! If you remove the rear cover it should show a couple bolts down at the bottom. I drilled holes in the cover so I could remove/replace without having to take the cover off anymore. Hopefully it works out!
2000 Limited | e-locker | 33's | Skids/Sliders | TRD SC | Sold
2007 Limited | V8 | RCI | OME 884/895e | 255/75r17 | JBA's
volkinator is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 07:34 PM #3
DarenS DarenS is offline
DarenS is on a distinguished road
Have you visited the Service Manual thread? The information you seek is there.
Service Manual Download Links
Specifically, you will need 06200510.pdf from the 2006 service manual.
2008 T4R Limited 4WD V8 | Stock Rims | Michelin 270/70-18 LTX M/S 2
2004 Greyhound | 25 Races - 3 Wins | 0-45 MPH in 3 seconds | 45 MPH - Couch in 2.5 seconds | Retired in 2007
DarenS is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 09:22 PM #4
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
You can do anything you set your mind to. I believe in you.
But yes. 14 mm socket. Do the seatbelt bolt in the front, the pry off the back fuzzy trim panel, do the 2 bolts, 1 on each side. I think the seats are 27ft/lbs and seat belt is 31 for install.
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 11:41 PM #5
f250ben f250ben is offline
f250ben is on a distinguished road
Its completely possible, no problem at all. The two seat backs aren't connected to each other and don't provide support for each other. Each seat back (the 60 and the 40 side) is connected at two points on the bottom where they hinge back and forth, and they each have a latch point at the top that holds them in place. I don't have any good pictures, I'm not sure if I'm explaining this well.
Basically, the two seat backs are not structurally dependant on one another. They're independently connected to the vehicle.
I did the same thing you're talking about, but removed the 40 (single seat) section and kept the 60 portion. Made an extension of my drawer system/cargo platform that extends all the way to behind the rear drivers seat, replaces the 40 seat structure, and creates some extra storage cubbies underneath.
I drove around with the seat removed for 6 months before I made the platform, just to make completely sure the remaining portion of the seat didn't loosen or something over time. Its perfectly fine. Everything's solid. In fact, my 4runner with 205K miles is ALMOST squeak and noise free, while my wife's fiat with less than 40K miles sounds like its falling apart going down the road. I think that might have more to do with how crappy her car is though
Middle Seat Removal-img_2908-jpg
Middle Seat Removal-img_2909-jpg
Middle Seat Removal-img_2910-jpg
Middle Seat Removal-img_2911-jpg
f250ben is offline   Reply With QuoteReply With Quote
Old 02-04-2019, 07:29 PM #6
Awesome! Thank you
Old 02-05-2019, 11:58 AM #7
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
Flip the seat bottom up, remove two bolts using 14mm wrench/socket.
Remove the seat belt hold down bolt, also 14mm.
Fold seat back down, gently pry the carpet/beauty panel off the back of the seat.
Remove 2 bolts attaching seat back to folding mechanism, also 14mm.
I pull my seats out all the time, and actually run no rear seats most of the time for the sleeping platform. It's a 5-10 minute job.
blackoutt is offline   Reply With QuoteReply With Quote
Old 02-07-2019, 01:57 PM #8
grave's Avatar
grave grave is offline
grave has a spectacular aura about grave has a spectacular aura about
grave's Avatar
Attachment 323939
Attachment 323940
Attachment 323941
Attachment 323942
looks great. what material did you use? any reason you didn't go above the wheel wells to get full-width use of the rear area?
pet every dog
grave is offline   Reply With QuoteReply With Quote
Old 02-07-2019, 02:51 PM #9
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
My drawer system goes above the wheel wells. Great for storing what I needed in the drawers but the trade off is you lose about 2-3" of head room if you want to sleep back there.
This makes it difficult to open coolers with a hinged top. I need to carefully position my Sportsman 70 cooler to open it in the rear seat location f250ben pictures his. It needs to be inboard about 4" to avoid the curve of the roof, but not so far in as to hit the dome light.
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 02-10-2019, 08:30 PM #10
Thanks! all 3/4" plywood, gray deck sealer, and leftover marine grade carpet from another project.
My reasoning for keeping the platform low was similar to what @Boort said. Main reason was our rear platform needs to allow for 2 medium size plano lockers stacked, up to 6 total in the rear platform. That's the size of plastic tote we use, and I didn't want to be limited to only 1 high. That platform height is the max hight that will still allow 2 totes to be stacked, with the top one easily removable. I never thought about being able to open the coolers too, but that's also a thing. I'm not sure we could open a cooler easily in place if the platform was any higher.
Old 03-18-2019, 03:33 PM #11
Attachment 323939
Attachment 323940
Attachment 323941
Attachment 323942
I guess i missed this post before. Love that set up. I had a similar system in my old dodge dakota. May put one in the 4runner soon.
Sent from my SM-G950U using Tapatalk
back , bottom , place , remove , seat
safe to put a baby seat in the 2nd row, middle seat? 1996_Valencia_Owen 5th gen T4Rs 30 05-03-2022 08:43 AM
Middle seats removal? Mike552 4th Gen T4Rs 6 03-06-2019 10:30 PM
Having trouble folding my middle seat in my 3 row seat 4runner insaniak 4th Gen T4Rs 3 06-08-2016 11:33 PM
5th gen T4R - middle row seat belt fix wallyply 5th gen T4Rs 2 01-28-2015 02:58 PM
Toddler Car Seat For 2nd Row Middle ct221933 5th gen T4Rs 1 01-12-2011 05:35 PM
